viper1
06-11-2013, 04:19 AM
HobbyWing Seaking-120A/Turnigy Marine HELP !?
Second run on this ESC, it stopped in the middle of the pond, no response, at first I thought I had a radio problem, but then I was getting a response, but weird, like my input was delayed, could just get it back to shore.
I checked the radio all is OK.
But now the ESC is brain dead, I get a beep interval of about 2 seconds (according to the manual a signal problem)
The internal BEC still works
I checked output signal on the RX, is OK
If I connect the ESC to program card I can not program anything.
I tried re-calibrating, but I can't even get in the set-up mode.
Known issue? Any fixes?
Edit:
Also: It's not been under any stress at all, still setting up my new tunnel hull so it's under-propped and on 4s instead of 6s.
System is literally running cold. Not a drop of water in the hull either.
Edit:
