View Full Version : Futaba 4PKS-R and dual ESC Mixing
Livewire121
06-09-2013, 09:00 PM
I recently got a pair of AS26-150 BL esc's. But I'm having a problem getting them to work with my 3PKS. I can calibrate them both independently, but when I connect them to a y-harness one esc is fine (solid green LED) and the other does nothing
(red LED). I've changed Y-harnesses, receivers, plugged them in one at a time directly into the receiver. Then unplugged them, while they both have a green LED, plugged them back into the harness. And still the same, one esc spins the motor and the other nothing.
I have a DX3R and I was able to get them both to work, but its a first gen DX3R and it doesn't work with spektrum marine receivers. (with a range of a 100 feet on the water)
So I'm considering getting a 4PKS-r and want to know if anyone is using its dual esc mixing option??
Livewire121
06-10-2013, 12:25 PM
Is there anyone using this radio????
siberianhusky
06-10-2013, 12:50 PM
Did you disable the bec on one of the escs?
Livewire121
06-10-2013, 01:34 PM
Thanks for the reply. These esc's don't have a bec.
Richard
