View Full Version : turnigy typhoon 500 outrunner
iop65
05-20-2013, 01:21 PM
used 5s with the stock motor but was always a little disappointed with the speed ( max +/- 62 km/u with 42 carbon)
tried 4 different props but makes little difference
cells 4000 40 c where always rather hot ,as my ec5 connectors
changed the stock 1800 kv 6 poles inrunner with a turnigy typhoon 500 1800kv outrunner that i had
yeah man!!
speed up to 68 km/u with the same prop,this motor a lot cooler,ec5 connectors and the lipo's barely warm
run-time almost 1/2 longer!!
going to make a watercooled motor mount so i can prop up
this realy is a great motor!!
lenny
05-20-2013, 01:59 PM
Hey,
Good for you.
My buddy run one in a SV27 on 4s and it was running great to,
Lot of power and low amp draw to.
Than he tried this motor for the first time and I got it on video running,
And it was a hand full, But a little tweaking to it and it was running pretty nice.
Get some video's of yours running.:popcorn2:
http://www.youtube.com/watch?feature=player_detailpage&v=1Doq8-Z5DIE
iop65
05-20-2013, 02:28 PM
thanks
i put it in with little hope for better results ;it's 3mm shorter then the stock motor and weights about 40 grams less
but it's far better then i had hoped for !!
was not so much impressed by then increase in speed but more in the way it's so 'fuel efficient", with only the aircooling i think you can run the 42 mm carbon prop the entiry 5s 4000 mah lipo without stopping
when i made a proper watercooled mount i'll try it with a 43 mm cnc prop ( the stock motor ,lipo's and ec5 almost melted with this prop)
lenny
05-20-2013, 03:21 PM
You should go to 5.5 all the way,
And the setups will be much happier and I think they will run better and cooler to.
Outrunners have a fine line so be careful how you push them,
They are efficient to a point and than they get hot.
200f running is about normal for them.
iop65
05-20-2013, 03:47 PM
you got a point there Lenny
the reason i use ec 5 is because that sometimes the kids of my girlfriend run my boats and i wanted something that they ( and me ) can not connect wrong :-)
hard to believe that this is a 31$ motor ,used it in a 26 inch mono on 5s and a 37.5mm prop but it was a big surprise for me that it can move this heavy boat in such a way!
lenny
05-20-2013, 03:59 PM
Yes,
The same buddy is running a good $30.00 HK 1400KV in this geico on 6s and loves it.
http://www.hobbyking.com/hobbyking/store/__17720__XK3674_B_1400KV_Brushless_Inrunner.html
Zoom zoom.:tongue_smilie:
http://www.youtube.com/watch?feature=player_detailpage&v=d2EpdYjfidk
