View Full Version : Esc over voltage
Paul.h
05-19-2013, 09:43 AM
Just installed a new out of box mystery 30 amp esc. When I connect my 3s lipo battery, the esc sounds a musical tone and then starts a rapid beep, beep beep. The manual indicates that is an over voltage or an under voltage. I checked the 3s lipo and the voltage is 12.47. I am very new to this and do not know if the esc is bad or what to do. Any suggestions are very much appreciated.
Paul.
egneg
05-19-2013, 09:57 AM
What lipos is the esc programed for?
Paul.h
05-19-2013, 10:09 AM
I have no idea. I cannot get the esc to operate at all. Just continues to beep.
Namba328
05-19-2013, 01:46 PM
Paul what radio are you using?
Paul.h
05-19-2013, 02:45 PM
Tactic TTX240 2.4GHz The radio was working fine but the old esc made the motor stutter. A friend who has lots of experience said it was bad. The minimono never would go on plane. I bought the boat used and never got it to run.
sundog
05-20-2013, 09:34 AM
Do you have a way to discharge the lipo some? It is fresh and a little high in voltage, that may be the problem.
TheShaughnessy
05-20-2013, 09:49 AM
A fully charged 3 s lipo will read 12.6. 4.2 x 3 = 12.6. Seems more like a radio issue, lots of esc's I've dealt with will beep if they aren't getting the proper signal or calibrated right.
Paul.h
A friend took my whole boat and battery and brought it back within minutes. He said he only set the throttle range and it started working.
TheShaughnessy
05-20-2013, 09:50 AM
Yup radio issue
sundog
05-20-2013, 10:14 AM
Glad that worked out. I'll watch for that if it ever happens to me. :ohmy:
