View Full Version : Mean Machine nitro to FE
dirtnsnowrider
05-17-2013, 03:29 AM
I picked up this hull a few days ago from Remy at Aeromarine. The hull had seen better days but was still seaworthy and had no flaws except for some dirt and grime. I plan on running this hull on 5s to 6s. I do have all my UL-1 electronics and running gear to put into this hull if I need parts. I started this build last night at 8pm. Here are picks of the hull with the motor in.
9894198942989439894498945
dirtnsnowrider
05-17-2013, 03:32 AM
Here are some pics of an idea to mount the motor. I had not even began to think about what to do with this hull. As I pulled the motor I was looking at the nitro engine/fuel tank plate and how to work around that thing. Here is a pic of my bright idea in mock up form.
9894698947
dirtnsnowrider
05-17-2013, 03:34 AM
Here are some pics of the wood rails I finished cutting and waterproofing. I am using my leftover UL-1 motor mount to mount the motor.
989489894998950
dirtnsnowrider
05-17-2013, 03:44 AM
I will also be using my UL-1 flex shaft. I took the measurement of what length I needed an grabbed my dremel and cut her down to size. I will also be using my UL-1 motor until I find a suitable 6s motor to pick up and a reasonable price. I am also using the UL-1 collet. So far my total investment is the price of the hull and hardware which was a great bargain (thanks again Remy @ Aeromarine). Here are a few more pics of mock placement. I will glass the rails later today when I wake up from getting some sleep. I was able to strip, clean, polish the rudder and strut and start final placement of all electronics. Not bad for a few hours of work. She should be ready to hit the water after I glass the rails and solder the flex shaft end that was cut. I will also drill a secondary water line hole for the secondary pick up. Here is where she sits till I get some sleep.
989519895298953
dirtnsnowrider
05-17-2013, 06:41 PM
So I finished off the nirto to electric conversion on this mean machine. I glassed in the wood rails, drilled a secondary water line hole, mounted the secondary water pick up off the strut, put in the water lines and rigged the servo with a linkage this morning. Total cost for this build was just the price of hull and hardware. Remy really hooked me up. :buttrock: I added what I had from my UL-1 and now she is ready for the video shoot tomorrow morning. Total work time 4.5 hours. Check out the final product....
9899898999990009900199002
dirtnsnowrider
05-17-2013, 06:44 PM
A few more pics of the servo linkage and hull with applied stickers.
9900399004990059900699007
tlandauer
05-18-2013, 03:44 AM
Ingenious! That is the quickest/simplest way to get around the situation. The hull looks great with the stickers! Enjoy!:rockon2:
Post some vid!
dirtnsnowrider
05-24-2013, 12:10 PM
I test ran the boat and she ran very very wet. After yanking the strut up all the way and making another pass she was still very wet. I noticed that the stock hardware really has no room for adjusting the prop to a positive angle to get the nose up. The way my boat was made did not allow for that positive angle. I pulled out the stuff tube and cut down a ul-1 stuff tube to the desired length and shaped it. It still did not get the prop where I wanted it so I gut down some brass tubing that was a little bigger and mad a through hull stuff tube that would allow my other stuff tubing to slightly move when I yank the prop angle up. Now I am able to get the hull to ride the way I like. Now I am able to adjust the strut height and prop angle for any water conditions. The boat is only running on 4s.
9948799488
tlandauer
05-24-2013, 03:18 PM
HI, that thru the hull out side tube looks good. Is your first picture the way it is now? Just for your info, my MM strut ( bottom of the bore) is almost 1/4" above the bottom of the sponson, that is high but not crazy, I had a lot of input from other guys at the time when I was building mine. When it is set up like that, the strut actually needs 1* of negative thrust angle. All this assuming the COG is adjusted correctly. I had to elongate the hole on the strut blade so it can be set at that height.
Just for your info, hope you don't mind my $.002.
:beerchug:
dirtnsnowrider
05-24-2013, 11:59 PM
I love collecting spare change......... Yeah the last pics are what its like now. Before the prop was always negative by about 2-5 degrees. I had the strut way up about where you had it and I was still running wet because the prop angle was severely negative. After examining my options I decided to try this through hull tubing set up for a first time to see what kind of adjustments I can get vs. the normal set up. I have the strut drilled out but my flex tube was preventing the angle I wanted from the way it was glassed in. I have a feeling that I will be running and adjusting the set up on this boat for some time till I get it just the way I like. Thanks for the info as I will keep it logged so when I have trouble again I can refer to you settings a guideline. Best part is now my strut and prop can actually be adjusted.
tlandauer
05-25-2013, 12:52 AM
That is great, my stuffing tube is really "buried" in there with extra metal tabs and JB Weld, what size of the outer tube did you use? I like the multiple adjustability of this design, may be my next build...
dirtnsnowrider
05-26-2013, 01:03 PM
brass tube 9/32 x .014 (7.14mm x .355mm)
That is the size tubing that I used. The stock stuff tubing was replaced with a cut down ul-1 stuff tube.
Brushless55
05-26-2013, 03:45 PM
What is your CG set at ?
dirtnsnowrider
05-27-2013, 06:40 PM
9 inches from the rear. Around 32% with no batteries in the hull. I can place the batteries where needed depending upon water conditions allowing me to make quick handling adjustments on the fly. I ran the boat today and she ran dry and fast. The wind started to pick up so I moved the batteries forward to about 40% from the rear and dropped the strut and she handled the white caps like a champ. I live in the wildest weather that you can imagine. The morning will start warm and no wind at all. Give it 2 hours and it will be raining with 30mph winds. I wanted a fully adjustable boat with a set up I can dial in at the waters edge. I was very happy with my results today and had planned on filming the runs but the video glasses my friend gave me to use were not in the case when I opened it up.
dirtnsnowrider
06-21-2013, 05:45 PM
http://www.youtube.com/watch?v=e1lz4XGrIZk
Finally was able to get some video of my boat. Sorry for the video quality as my camera is old.
Heaving Earth
06-21-2013, 08:07 PM
Nice mm!
Looks like its running good, even tho your strut looks low? Can't tell for sure
dirtnsnowrider
06-21-2013, 08:19 PM
Nice mm!
I have been testing and testing and I seem to have the best overall performance when the strut is 3/16 of an inch above the bottom of the boat. I played around with it today for about 2 hours. When I have the strut all the way up positive she would just cavitate horribly. I slowly worked my way down till the boat started to keep the speed in the turns. She still cavitates a little bit from a dead start but I am happy with the way she is running. This boat really likes rough water which is a good thing for where I live since it is always extremely windy.
Heaving Earth
06-21-2013, 09:04 PM
Yeah mine is at about 3/16 too
tlandauer
06-22-2013, 04:02 AM
Video looks great! Just love to see how the MM corners!:buttrock:
Love how clear the water is, nice spot to run!:rockon2:
Brushless55
06-22-2013, 09:11 AM
Wow, that runs better than I thought it would on UL-1 power!
great job man :rockon2:
