View Full Version : lipos for reciever?
JimClark
07-04-2008, 04:12 AM
What are you using for receiver batteries? Anyone using Lipos for their reciever batteries?
What about these?
http://rclipos.com/PolyquestLP.htm
JIm
Fade2Gray
07-04-2008, 05:04 AM
Hi,
In addition to the question above, is anyone using a battery for the receiver and if so what is the advantages?
I run BJ and SuperVee, both of which are using the existing two 7.4v lipo's that power the motor.
Cheers
JimClark
07-04-2008, 05:19 AM
because your ESC has BEC you can do that but with the risk of glitching. I run a separate reciever pack
Fade2Gray
07-04-2008, 05:25 AM
Jim,
In risk of sounding silly and dumb, what is BEC ? What does BEC stand for?
I thought BEC was a brand name for a receiver.
Thanks...
G Doggett
07-04-2008, 06:24 AM
B E C = Battery Eliminator Circuit.
Meaning that because the receiver is powered from the main power batteries a receiver battery is not required.
A nice idea in theory, but prone to introducing glitching particularly with brushed motors.
Much better to have a seperate battery for your receiver.
Graham.
longballlumber
07-04-2008, 07:00 AM
What about these?
JIm
Good morning Jim,
This just my .02 cents... I think it's kind of a wash. The lipos are nice and light and easy to place, but then you need to have a voltage regulator to maintain a constant voltage to the RX and the servos. Just another component to place and now that you have two different items (lipo and regulator); I don't think you save much weight if any... What are your thoughts? I have seen several people using them.
Mike
J Solinger
07-04-2008, 07:10 PM
Personaly I use 6v camera batteries and toss them out at the end of the season but they can be expencive too. I have seen a variety of batteries used. I haven't done this but a few folks have been using 9v batteries for years with no regulator and have never seen a problem. I Don't think there would be any problem with using a 7.4v lipo.
JimClark
07-04-2008, 07:14 PM
Joe do you just solder the wires on them or have you found a small battery case for the camera batteries
Mich. Maniac
07-04-2008, 07:20 PM
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001208072&I=LXSGC1&P=K
this is what I prefer even with low voltage
Jeepers
What about these?
JIm
I use a 5cell 1200mah nimh pack.
I heard of people using 9v batteries also but I have not tried it,
J Solinger
07-04-2008, 10:05 PM
I just solder the wires and put some velcro on the back.
Ctonez
07-05-2008, 12:06 AM
I've been using similar little 1000mah 2S lipos for my reciever batteries for about a year now...never a problem.
I use el cheapo brand for those packs, $15ish at the LHS that sells mostly Heli-stuff.
