Crusty128
05-15-2013, 02:59 PM
Hi everybody,
I purchased a fully upgraded EKOS from a member last year, and here is its setup:
bare hull with 2 layers of blue carbon fiber inside the hull.
Installed:
FC motor mounts
FC rudder
FC stingers 4mm
Flush hull water pick ups
Carbon fiber battery trays
Feigao 9xls with cooling jackets
Turnigy 120s
2-Hyperian 4s 3300 mah
Carbon fiber 3/16 props (counter rotating)
At the moment, I run it on 2x3S 40-80C 5000mah batteries with the Graupner 2 bladed 40mm- 56mm pitch props, and
it run smooth and handle really well (as far as I know since I'm not afraid to tell you that I'm new in this hobby).
When I want more power, I just plug the 2-Hyperian 4s 3300 mah batteries in it, set the esc's for it and WOW, it run like this:
http://www.youtube.com/watch?feature=player_embedded&v=yF6mx7pS_lI
My question is:
When I purchased this boat from a member, it came with 2 other props from Graupner: 2 bladed 45mm- 63mm pitch.
Is there any interest for me to test those ones?
Should I'll be tuning the thrust, the CoG, and whatever (this scares a bit since I've never done it before)
If I put those bigger props, should I run my EKOS with the 2x3s setup or the 2x4s ?
thanks folks !:Peace_Sign:
If you want pics of the boat, just go here: http://forums.offshoreelectrics.com/showthread.php?35854-completely-upgraded-King-of-Shaves-C1
Installed:
FC motor mounts
FC rudder
FC stingers 4mm
Turnigy 120s
My question is:
