View Full Version : BJ29 replacement collet
<AJ>
04-29-2013, 06:08 AM
Could someone point me in the right direction for the correct Octura collet to fit the BJ29 plz
Regards AJ
srislash
05-02-2013, 11:59 PM
You want the "short" one http://www.offshoreelectrics.com/proddetail.php?prod=oct-ocfhe5mm15S
It is what I used.
tlandauer
05-03-2013, 05:36 AM
Don't be surprised if the set screw for the motor shaft of this collet doesn't clear the stock motor mount. You need to grind away a bit of the aluminum just below the collet ( on the motor mount, of course), you will see it and it is real easy to do. Assuming that you are using the stock mount, so many posts lately with so many people doing mods I don't remember if you are among one of them.
Cheers.
<AJ>
05-07-2013, 04:45 AM
Thanks
