View Full Version : Titan 29 or H&M Drifter rtr
KjoTTbein
04-26-2013, 02:54 AM
Looking for a complete rtr Titan 29, H&M micro drifter or drifter s. I will consider other Catamarans V-hulls also.
Need to be hitting speeds over 50mph
sundog
04-26-2013, 12:30 PM
I have an RTR H&M micro Drifter that has all the goodies, but has never been in the water! The ponds around here are too small, and the lakes too big and choppy. I'm told it should easily top 50mph and possibly 60 depending on prop choice/tweaking the strut. Has a Jeff Wohlt wire drive (with1/8" prop shaft) and bearing strut, Etti offset rudder, Nemisis Blue 5915kv brushless, HK SS 125A esc with separate bec, 8mm bullets, flotation. All set up for 2S2P including Deans plugs and parallel adapter. Has a 3 ch 2.4ghz Flysky receiver that I'll remove unless you want that too. Prop not included. The 'windows' are electrical tape so can be removed. I have over $400 invested it and can't even run it! I'll take $300 shipped (conus) for it if you're interested.
KjoTTbein
04-26-2013, 01:07 PM
Does it come with batteries?
sundog
04-26-2013, 02:18 PM
I might be able to work something out. Do you want the Flysky receiver? Will you need a radio?
KjoTTbein
04-26-2013, 04:03 PM
Already got receiver and transmitter so won't need that.
sundog
04-26-2013, 04:44 PM
Yes, I have two Turnigy 2200mah 25C to 35C lipos that have had little use (and Deans plugs on them) that fit the space in the Drifter. I'll let them both go for $20. That would be $320 for the lot, shipped. And I found a plastic 31mm prop you can have if you want it, but you will want to get an Octura x430 (for starters) for more serious playing.
KjoTTbein
04-27-2013, 06:29 AM
Got an offer to buy same boat with carbon floor, race prop, and batteries for $375. And i can see i have forgot to mention i live in Norway. And postage over here is a bit more expensive.
So will probably go with that one or a Titan 29 if someone has for sale.
sundog
04-27-2013, 10:28 AM
Yes, I guess postage would be more! FTR, this boat doesn't need a carbon floor, it is a strong hull. Best of luck, Sdg.
