View Full Version : Building a tool bag am I missing anything
Geeves
06-30-2008, 10:08 PM
Building a tool bag am I missing anything?
(1.) 10mm Wrench -Loosing the cable coupler
(2.) 12mm Wrench -Loosing the cable coupler
(3.) 1.5mm Hex Key -Remove cable coupler from motor shaft.
(4.) 5.5mm Wrench -Nuts on motor mount
(5.) 2.5mm L-Hex Key -Screws on motor mount
(6.) 2.5mm Hex Key -Remove motor from motor mount plate
(7.) 2.5mm T-Hex Key -Remove radio box from hull
(8.) 2.5mm Hex Key -Remove trim tabs
(9.) 2.5mm Hex Key -Remove turn fins
(10.) 3mm Hex Key -Adjust turn fins
(11.) 3mm Hex Key -Adjust strut angle
(12.) 7 mm Wrench -Adjust strut angle
(13.) 2.5mm Hex Key -Remove strut from hull
(14.) 1.5mm Hex Key -Remove rudder blade
(15.) 2.5mm Hex Key -Remove rudder mount from hull
(16.) 2.5mm Hex Key -Remove rudder control arm
(17.) 2.5mm Hex Key -Remove rudder linkage from rudder arm
(18.) Pliers -Remove rudder linkage from threaded push rod
(19.) 1.5mm T-Hex Key -Remove drive dog
(20.) 7mm Wrench ? -Remove Prop
(21.) Phillips Screw Driver -Remove Servos from radio box
Mich. Maniac
06-30-2008, 10:24 PM
You are missing ALOT. You should see what I bring. Its seems ridiculous but I still sometimes dont have what I need, (or others need). its amazing really. A few thing i see missing, depending on your run site....
soldering iron
shrink wrap
volt meter
charger
spare velcro
grease
RAGS
hatch tape
scissors
radio batterys (or charger)
spare and diff. size props
spare prop nuts
eclipse
06-30-2008, 11:17 PM
gloves
swimming shorts or fishing pole
glue
screws incase rudder screws brake
extra motor coupler
just to name a few more
skidooguymxz550
06-30-2008, 11:52 PM
quick setting two part epoxy
ca glue
spare servo
thin ply wood
Geeves
07-01-2008, 08:59 AM
For a perfect supply bag I should carry..
Tools:
1.5mm Hex Key
2.5mm T-Hex Key
2.5mm L-Hex Key
3mm Hex Key
5.5mm Wrench
7 mm Wrench
10mm Wrench
12mm Wrench
Pliers
Wire Cutter/Strippers
Soldering iron
Scissors
Volt meter
Running Supplies:
(2) Chargers
(4) Packs
Grease
Oil
Hatch Tape
AA For Radio
Extra Parts:
Screws incase rudder screws brake
extra motor coupler
Spare and diff. size props
prop nuts
Spare servo
Extra supplies:
Quick setting two part epoxy
ca glue
thin ply wood
RAGS
Ocean Racer
07-01-2008, 02:28 PM
looks good to me. Me i personally bring a 2 batts a boat and a radio ad thats good enough for me.
SweetAccord
07-01-2008, 06:39 PM
You all forgot the wife or girlfriend. . . .
smm_cbf
07-01-2008, 07:09 PM
gosh, is this for racing or just a lake run?
Ub Hauled
07-01-2008, 07:28 PM
If you are using AM/FM radio, crystals for Rx and Tx...
You never know if one goes out when you drop the radio
or if people have the same frequencies as you for some reason.
being extra cautious.
Geeves
07-01-2008, 08:17 PM
Lake run but its 4-5 hours form home and a bunch of children will be using the boat. I bought it more as a family toy.
Ub Hauled
07-01-2008, 08:21 PM
Mich. Maniac
07-01-2008, 09:23 PM
No We didn't!!!:spy: :spy:
rocket-ron
07-03-2008, 08:30 AM
And don't forget your Craftsman Tool chest on wheels to carry it all,(or a small U-Haul trailer!:laugh: Ron
Ctonez
07-03-2008, 12:39 PM
I'd add a temp gun or infrared thermometer for checking motor/esc/battery temps after long runs.
SweetAccord
07-03-2008, 02:24 PM
Temp gun! Good one to not forget . . . .
Mich. Maniac
07-03-2008, 10:06 PM
Honestly if its just a lake run which is only a few minutes away for me I just take the boat, hatch tape, radio, and scissors. Oh and recovery boat. But for times when Im outta town I take the whole kit a well you know
Jeepers
07-05-2008, 02:15 AM
I used to carry a volt meter but I have never used it! nor has anyone ever asked for one at the lake and this is over 3 years of racing! ocasionally someone asks for a soldering iron, rare though.
MAYDAY
08-07-2008, 08:09 AM
Amazing how much stuff you find youself needing when you get to the lake. I was always forgetting something till I found the right hauler bag. Since I didnt see any mention of the bag it self thought I would share this with you guys. Makes taking a trip to the lake like fun again. http://www.kintecracing.com/Boat_Tote_Bag.html
Geeves
08-08-2008, 10:34 AM
My bag look the same but 6 " shorter and green
lonewolf
08-09-2008, 12:37 PM
Nice bag do they make longer ones 1/2 my obats are 36 in or longer with hardware....
