View Full Version : micro servo for 21" mono?
phase
06-29-2008, 06:36 PM
hhi i have been running a ACE RC DS 1015 servo for steering on my 21" oval racer.. but i think havving a big servo to control a little rudder is overkill.. it also adds alot of weight.. i was thinking of running a mini servo for it.. i was thinking maybe a hitec HS85MG servo.. what do you guys think about this idea? :help:
check it out
http://www.hitecrcd.com/servos/show?name=HS-85MG
phase
06-29-2008, 06:47 PM
oh and i also found this
http://www.hitecrcd.com/servos/show?name=HS-225MG
i am gonna probably be running this octura rudder once it is back in stock
http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc4wrmca
G Doggett
06-29-2008, 09:21 PM
Just use a Futaba 3003 ( or equivalent standard servo) and save your money.
Weight is not really a problem.
Graham.:rockon2:
phase
06-29-2008, 09:47 PM
lol.. you dont think its a problem when my speed control is on that side also.. it is leeaning to one side really bad... so i think i will get a nice little servo..
G Doggett
06-29-2008, 10:08 PM
Your problem is not that the servo is too heavy but that you have too much weight on one side.
I usually have servo on one side, receiver and receiver battery pack on the other, and ESC in the middle.
The boat must be trimmed so that weight is equal or maybe a little more on the l/h side to counter prop torque.
Graham.:rockon2:
phase
06-29-2008, 10:17 PM
ok but i still dont think i need a huge servo to power a verry small rudder.. id rather have it as a backup for something else.. so what kind of servo do you guys think i should get.. i NEED a mini servo... BTW thanks for the info Graham..
eclipse
06-30-2008, 06:27 PM
i have seen people run mini servos on small cats but i think it will be better for you to run the bigger one..
rhinopole
06-30-2008, 07:10 PM
I use a Hitec HS-225mg in my Nostep 1, works great.
phase
06-30-2008, 10:01 PM
how big is the Nostep 1?
rhinopole
06-30-2008, 10:46 PM
22.5 X 7
phase
06-30-2008, 10:59 PM
o ok.. thats cool but im just gonna use the servo i got for now
mtgoat
07-01-2008, 08:11 AM
This is the exact servo I'm using in the 21" mono (MHZ Speed Star) that I'm building.
phase
07-01-2008, 09:31 AM
oh well i already installed the bigger servo
