View Full Version : Seaking 180 problem
704Authentic
03-28-2013, 11:09 AM
Programmed the ESC. Made a few runs - slower than expected. Temps at 90.
Cannot get back in to check settings.
Followed wiring sequence (ESC w/out built-in BEC.) and batteries are charged.
Looking at flat lines on program card and motor moves when it beeps, when connecting power pack to ESC.
Lost.?
lenny
03-28-2013, 01:44 PM
Hey.:tiphat:
Is the esc rx/program plug in the right way in the program box ?
And is it in the slot at the far right of the program box ?
Also you can just us a 2s pack to work with when trying to program the esc.
Have any pictures you could post or a video to see what you are talking about ?
Are you using the stock tactic tx & rx ?
If so did you calibrate the tx to the esc first and also set the tx throttle trim switch to R , Before you tried programing the esc ?
MAMBA2200
03-28-2013, 02:25 PM
The slow run was probably caused by the lvc set to high turn it off when u get back in to program it and time your run start at 3 min and stop
Sent from my FE Phone
704Authentic
03-29-2013, 10:04 AM
rx/progam plug in far right.
Using different battery packs.
Stock tactic tx & rx.
Calibrated the tx to the esc first and also set the tx throttle trim switch to R , before trying programing the esc. Yes.
But, I may not have used the "reset" button each time after "value".
Still unable to get in, motor beeps and looking at horizontal lines on program card.
704Authentic
03-29-2013, 10:09 AM
You are probably correct - Looked like half power. Will turn off lvc, when/if able to get back in.
lenny
03-29-2013, 10:47 AM
Can you post some pictures of everything in the setup & tx/rx /card/ please ?
And did you try a rebind to the tx to rx ?
704Authentic
03-29-2013, 12:41 PM
Sorry, unable to download pictures at this time.
Rebinded tx to rx. Motor runs, red light on ESC comes on under full power.
Still looking at horizontal lines on program card.
My Set-up:
Castle 1415 2400kv
Seaking 180
(2) 4500mah 2s 50-100c
All on 6.5 bullets
42x55 prop (starting point)
foamed
lenny
03-29-2013, 01:31 PM
Is your esc rx plug,
Plugged in to the program card slot on the right hand side of the card ?
And the plug wires black, red, white, White wire of the plug on the right side of program card ?
704Authentic
03-29-2013, 05:49 PM
All the way to the righthand side - yes, in that extra funny marking.
White wire of the plug on the right side of program card - yes. (Red wire cut.) ?
lenny
03-29-2013, 06:30 PM
No red wire cut,:nono:
Are you using no bec ?
With a separate rx batter pack in the setup ?
704Authentic
03-29-2013, 07:45 PM
Yes, using a separate rx battery pack and following wiring sequence for ESC w/out built-in BEC.
I read on OSE '...cut the red wire.'
Not correct?
lenny
03-29-2013, 08:10 PM
When doing separate rx just pull the red wire connector out of the plug,
Than you can always put it back when you need it.
Try to reconnect the red wire and just use the internal bec of the esc and try the program box again.
jsturess
03-30-2013, 05:11 AM
Which version of seaking?
704Authentic
03-30-2013, 10:18 AM
180 with 4 extra cap banks, I think it's a V2.
704Authentic
03-30-2013, 10:42 AM
It's a Seaking 180, a recent purchase from OSE.
704Authentic
03-30-2013, 02:53 PM
Put the "Red" wire back and wham - There it is! I guess everyone knew that except...
Just got back from the Lake - looks like it's getting close to my Goal of 60mph.
Big Fun! Will GPS next.
Just wanted to say "THANK YOU LENNY!"
Still don't understand how the Sky gets brighter when the Boats running good.
lenny
03-30-2013, 03:08 PM
Glade to help,:tiphat:
But pictures would have made things easier for me and you.:beerchug:
And look out for them blow overs chasing speeds and get some video's.:popcorn2:
