View Full Version : How to replace stuffing tube?
petej
03-20-2013, 12:07 AM
Hi,
The flex-shaft broke between the end of the stuffing tube and motor coupler and shred the stuffing tube.
Any tips or techniques on how to remove or repair the stuffing tube in the MC hull are appreciated.
Pete
95615
chipgibbs
03-20-2013, 06:33 AM
Heat the brass tube with a soldering iron until the epoxy lets go, then pull it out.
I just did mine yesterday.....used a propane torch for a few seconds, with a bit of twisting and force, it came out without any hull damage.
BlackSnakeRacing
03-20-2013, 04:54 PM
I CAREFULLY use a cut off wheel on the dremel, remove the epoxy from the top of the stuffing tube so that only the bottom half is held by the epoxy and then i heat it with the soldiering iron and it pulls out pretty easily and leaves a nice clean area to install the new stuffing tube. You can also use a sanding drum if your not confident with a cut off wheel, just takes a little longer
Heaving Earth
03-20-2013, 06:16 PM
Heat it up with hair dryer and pull it out
petej
03-20-2013, 11:34 PM
Using my wife's hairdryer, at the entry point on the bottom of the hull, all was loosened and easily removed.
Thanks for the tips.
Pete
