View Full Version : Minimono!
Sarpi
03-16-2013, 12:25 PM
Hi! New to this forum! Just bought a minimono from tower! any oil required for the brushless motor besides greasing the shaft? thanks
Serpents811
03-19-2013, 09:51 PM
no oil on the motor
Sarpi
03-19-2013, 11:05 PM
thanks! thought i needed to put some kinda oil sometimes! like i do on my heli brushless! scorpion oil!
Billy Barnacle
03-25-2013, 04:51 PM
Sarpi,
Welcome to the forum and the wonderful world of RC boating:smile:
I have to disagree with Serpents811's answer for the following reason(s)...
Please goto AQ's website and download the manual for the SV27R. On page 8 they say to... "10. Remove the motor from the boat and spray the entire motor with moisture displacer. Make sure to fully saturate the motor."
On page 6 (SV27R manual) they suggest using one of the following water displacer's... WD-40, CRC-56 or Corrosion-X. Personally I do not agree with the WD-40 suggestion and would not use it for this application, it rots rubber and I feel that it would cause long term damage to the internals of the motor. I have not heard any bad about Corrosion-X, perhaps other members can comment on that product.
I have the AQ Wildcat EP, it has a larger version of the MM's motor, here's a pic... http://www.aquacraftmodels.com/boats/aqub1810-wildcat/aqub1810-features.html.
I couldn't find CRC-56 in my area so I got this stuff... http://www.rscbrands.com/products/product_images/VL_L212.jpg at the local Wally Mart - I've been using it for over a year without any issues. During the summer months I pull my motor out every 3 runs or so and saturate the motor per the instructions in the SV27 manual.
We have long winters in my area, that means long periods of non-use, I soaked my motor with the above stuff before putting her away for the winter. Weather's starting to warm up, so I took my boats out of storage and bin gettin them ready for spring / summer; the WC motor still runs like new, something to be said for that.
For the wire drive you'll want to use this stuff... http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMPH8&P=**Missing%20Data** - that little tub will last for a long time.
Southwest
03-25-2013, 08:27 PM
Id put oil on the bearings after a days running and that's it. Corrosion-X-easy on spray around the servo wires as time will makes led wires brittle if not kept dry. Spraying X on outrunner innards is for useage in airboat motor that are exposed to mist from the water so rust doesn't collect.
Sarpi
03-26-2013, 03:02 AM
Many thanks Billy! Sitting here in India does'nt make things easy ordering stuff! mind you i have ordered Corrosion X the non spray bottle as they have restrictions on the spray for USPS as well UPS & Fed ex! Meanwhile ordering the speed grease! Grateful to have u guys on the forum to help!!!
