View Full Version : Platinum Princess
graill
03-09-2013, 05:55 AM
Havent posted anything in while due to my fathers passing a few months ago, kinda lost the drive to do anything but slowly getting that back. Will be handling his estate so posts will be off and on when i get time as i have to go to a couple other states, back and forth to handle business. Moved into his house in Tumwater last month.
Got a bit of the posting bug so here are a few pics of the parts so far. Duplex Stainless steel duct work was done by a local gunshop with laser welding through out, my designs. High temp ceramic liners and ducting made by me. The fully baffled fuel tanks are stainless but also low carbon alloy and are not as brittle as the exhaust ducts but they wont be taking 800 degree heat either.
Fittings are Beswick high flow quick disc made of stainless. Intakes are fully functional and will be used to assist in cooling the exhaust along with the main duct work (not shown) and for Turbine intake both sets flow a combined (4) 170 CFM/80.2LPS. More than enough for both turbines running at max rpm. Eventually i will be using a CF dual intake feed ductwork with a center K&N 200 CFM flat filter, that way i can get rid of the restrictive intake screens these jetcat turbines have. Mockups of a couple parts are in the photos for comparison, they got them pretty much exact. Keeping the Princess To scale with intakes and exhaust.
9496894969949709497194972
graill
03-09-2013, 05:59 AM
More.
The exit tube still needs to be trimmed below the ceramic liner, right now it is just sticking out a bit. need to final fit before trimming.
9497394974949759497694977
graill
03-09-2013, 06:01 AM
Another bunch.
9497994978949809498194982
graill
03-09-2013, 06:02 AM
Last bunch.
9498394984949859498694987
electric
03-09-2013, 09:13 AM
Nice job. Really a whole another facet of boating with those engines. I love the sound of them.
ManuelW
03-09-2013, 12:39 PM
amazing job done on the welding, whats the weight of one fuel cell? Your exhaust system looks pretty amazing too.
At the gearbox cover, what is the 2nd 90° Festo connector beside the connector for the fuel line (lubrication) ? That 2nd connector does not exist on a "standard" turbine :wink:
regards,
Manuel
graill
03-10-2013, 06:17 PM
regards,
Manuel
You know why Manuel, Grin. The short version for anyone else is it is for extra fuel bleed off as the original cooling (lube) slots for the shaft are much larger now and i do not need excess fuel pushing out seals.
graill
03-10-2013, 06:29 PM
Manuel, the fuel tanks weigh a hefty 2 and a quarter pounds each, they are crash rated to 100 mph (Guaranteed by the manufacturer not to rupture, no other tanks on the market can claim that). This boat will not see speeds over 75-85 range, there is no reason for that, plus it still exceeds scale speed by a large margin.
There is some rumbling in our state legislature (washington st.) regarding RC Models that use hydrocarbon fuel of any type and crashes, this has mainly to do with planes and helis crashing on property and catching things on fire because of ruptured fuel cells. Since i use JET-A i figured better safe than sorry. The fuel tanks are fully baffled too to help feed and prevent tank ruptures on impact, again this is simply a safety precaution. 3 extra pounds of extra stainless steel verse what it would have been wont hurt a thing.
graill
03-23-2013, 05:36 AM
The exhaust ducts were sent to Dallas Tx to get a PYROSIC coating (see link) not even a pound of extra material but it will drop the exhaust temp by 200 degrees plus and then I can forgo the heavy ceramic insulators I had planned. The video link shows a ducted fan exhaust but the temps for bare Pyrosic are way to high for inside a closed boat without cooking it.
http://www.high-temperature-composites.com/video-aircraft-engine-heat-exhaust-duct.htm
Attached are pics of the inside cores for the new heat shields made with micro louvers. Shown with the stock heat shield. They will be part of a sandwich of high heat aluminized Kevlar. I will make a set of extenders for the transmission later.
958929589395894
ManuelW
03-23-2013, 06:43 PM
Definitely a lot of engineering necessary for the special exhaust types you want to use. Imho for that solution not an option but a must-have. From what I see it will come out pretty decent. My round exhaust cones will be shipped on Monday, hope I can present them here at the end of next week.
Not as spectacular as your parts, simply "adapters" from the square stock exhaust to a round exhaust with 85mm diameter.
regards,
Manuel
graill
03-23-2013, 09:56 PM
We are both doing some neat stuff but I have no doubt about your end project result being a cut above mine Manuel. Ideas, that's what makes hobbies great. :smile:
kingwrench
03-23-2013, 10:59 PM
Neet stuff
ManuelW
03-24-2013, 04:06 PM
by the way when I was again looking through your thread, I wondered what surface area your exhausts have at the exit?
Reason I ask, my stock turbine has a rectangular surface with 81x55mm (equals 4455mm²). I've then chosen the diameter of my new exhaust pipes with round exit the way, that the surface area stays equal or gets bigger to avoid additional pressure and therefore temperature increase in the system. And my new ones will have an outer diameter of 85mm and inner diameter of 83mm giving a surface area of 5410mm².
Basically a diameter of 75mm would have done it but right at the point where it gets from rectangular to circular it would have decreased diameter.
Your exhausts look smaller in area, therefore I'd be interested to hear your approach to the system as I'm pretty sure the dimensions did not just come from nowhere :smile:
regards,
Manuel
graill
03-26-2013, 01:19 AM
@Manuel
Indeed there was a lot of thought that went into the method and madness. Some history, I worked on turbines at all levels from depot to on site user for 22 years, including maintenance, troubleshooting and repair. The project. I contacted some folks at GD and went through a question and answer about the exhaust duct on our AGT 1500 and picked their brain about exhaust velocity verse pressure and heat, ultimately the simple solution...and it was very simple, is to keep the (exhaust pressure) positive under all ramp modes and ensure hg increased and did not stall or decrease as the turbine ramped up. That is from idle to max power. Plus there must be a positive pressure when the engine is stopped to prevent negative (exhaust pressure) which will let hot gasses heat soak or basically flow back against the cooler parts of the engine creating heat damage. You read about melted Festo fittings from time to time in helis or aircraft and this is the cause. Backdraft in a stopped turbine is very bad.
The original design did not include the "Hump" you see with the finished ducts they used to be a big rectangle 90x50 (4500) slightly up from the stock exhaust jetcat has which is 83x36 (2988) at the base exit point which was way more than enough considering the small exhaust pressures of these toy turbines so we lowered the cross section until velocity picked up and pressure went up past the 18hg mark ensuring enough flow. My friend then backed the cross section toward the exhaust outlet and created a high pressure area that did two things, first it provided a static low pressure area where air would not pass after the engine was shut down and the primary reason was to create a ramp to maintain velocity exiting at a near 90 degree angle, which it does not do now. The exhaust is a convergent type to the vertical exhaust point at which it expands to a lower pressure stack and exiting, a perfect situation, high pressure to low pressure. Finished current cross section is 90x35 (3150). With the velocity it is plenty. Probe temp is almost 600c at max power which is well under spec (750) provided by Jetcat.
The actual exhaust cross section is very tiny on the "ground" unit JetCats. The volume is almost 1/3 less than the total exhaust diameter cross section after figuring in the transmission bell that blocks a huge portion of the exhaust exit. So any figures over with a cross section over 2500 will be sufficient at all levels. The one thing needed for any Turbine exhaust is to ensure velocity increases under the entire operating range and hg does not stall when using an exhaust duct. We do not have the luxury of free flow exhaust or cooling air that aircraft do. :smile:
I am eager to see your exhaust and what you have done for a solution to prevent hot gasses from flowing back into the stopped engine, compressor stage, as from what I understand your exhaust system is full divergent.
graill
03-26-2013, 01:27 AM
Couple shots of the finished Radio box with heat shield. The top frame is removable. Though nice looking I am going to remove half the screw studs as the maker went overboard with them. :smile:
9610296103
egneg
03-26-2013, 07:56 AM
Looking forward to pictures of the finished boat James.
lavigna
03-26-2013, 11:16 PM
Unreal. Keep it up!
ManuelW
03-27-2013, 04:23 AM
Hi James,
yes my exhaust system is fully divergent but I did some other tweak, hopefully works as desired. For preventing of hot gasses flowing back into the stopped engine, I think that solution is already included from JetCat. I'd guess you have the ECU with the older software for the cooling down. Which means like it is 5-6 seconds stopped, then for 3-4 seconds the electric motor gives some cooling and that process repeated. Basically a pulsed process, seems as that one created some troubles.
They now changed that to a permanent cooling, immediately after the 1st stage stops, the E-motor jumps in at 4000rpm and provides permanent cooling till the inner temperature is below 100° Celsius. At land when the prop shaft can spin unloaded, the electric motor will already start when the 2nd stage is still a little running from its momentum of inertia.
So can't imagine that with the updated system hot gasses can flow back to the compressor stage, therefore I didnt take that into consideration for the exhaust system.
regards,
Manuel
graill
04-01-2013, 05:22 AM
@Manuel
2 putties, Pyro-Putty® 950 and Resbond™ 907GF. Not sure what your sealing solution is and if you will have any down draft concerns. It molds and dries to any shape beautifully and neatly. The Resbond is preferred over the pyro putty because it can be removed with a bit of effort cleanly and works perfectly for sealing any gaps and imperfections the exhaust duct may have when mated to the modified Turbine exhaust. It prevents downdraft bleeds, which in my case was a problem and baked a small portion of the hull in one spot, I caught it so no damage, still I have decided to put a 6oz Kevlar/cf mix in the high heat area using some epoxy resin made for JetA and Kerosene, Max GRE, Chemical list shows gas, jet fuel and kerosene resist as excellent.
I have to talk to Jetcat here about the new programming then as I do have the older ECU, it sounds like they did it right this time. Mine still does the short runs and is inefficient.
graill
04-01-2013, 05:25 AM
Thank you sir. :smile:
hanspeter
04-16-2013, 06:25 AM
Hi james I've seen much. but that is perfect. I think you need next also a probation officer hahahaha
greetz hanspeter
graill
04-16-2013, 06:46 PM
greetz hanspeter
Greeting Hanspeter, very nice to hear from you, as for the probation officer, I hope not!
regards, James.
graill
04-18-2013, 09:59 PM
Finally roughed up the interior and cleaned the remaining FE dust out. Fitted a brown paper mockup of the main mechanics area several times until I got a proper fit. Sprayed some 6 oz Kevlar/CF mix with Aquanet (prevents fraying) and let it dry, then cut to shape. I then used Max GRE-R, a purpose made epoxy for areas using Jet-A or Kerosene and high heat, such as aircraft engine compartments APU enclosures etc. After wetting the area I fitted the single large piece and began the hour job of laying the new substrate down...at which point one of my Korats got curious....with no warning Tom jumped from the floor into the boat onto the new, very wet Kevlar....with the same speed he landed he jumped out and in the process snagged a thread of Kevlar with his claw and B-lined it to a hiding place I couldn't find him.
I had to slowly work the thread back in and all but a tiny 1/8 bunch went back down but the damage is done, I have a perm blemish just over a foot long. So I though take the monstrous piece back out or leave it lay since it went in and looks relatively ok, I decided to leave it and used vacuum bagging material on the surface and edges to seal them and let it dry. Not bad. I can still hear my cat trying to mew and apologize, I have a soft heart, so I didn't kill it. Grin.
I also fitted, cut and installed the aluminized Kao-wool to both sides, pics included, 8oz total weight for the two pieces. The Kevlar installed is 11 ounces with resin by weight. Also included is a picture of the perpetrator, Tom is the front cat.
9737097367973689736997371
graill
04-18-2013, 10:04 PM
Aluminized Kaowool install. This isn't all the heat shielding, though it is the two largest pieces.
graill
04-24-2013, 06:07 PM
Just got the estimate from Pyrosic on my exhaust ducts and I do not think I will be using their solution. A quote of 12-23 thousand dollars, included retooling and cutting the exhaust ducts up as they said using it as a coating would not work so they said they would have to use my ducts as plugs, I told them no and to forget the whole thing and to send my stuff back. WOWSERS, as Scooby Doo would say.
They said their type of business was for "People with the proper budget".......I laughed.
