View Full Version : Mixing rudder channel with 2 motors? Is that possible?
paultbg
03-05-2013, 10:02 AM
Hello
I plan to build a scale boat.I will use 2 motors, 2 esc, a 9 channel tx+rx like this one. (http://www.hobbyking.com/hobbyking/store/__8991__Turnigy_9X_9Ch_Transmitter_w_Module_8ch_Re ceiver_Mode_1_v2_Firmware_.html)
I would like to be able to mix the rudder channel with the motors so when I turn right the right motor will slow to 80% lets say.
Do you thing this is possible ? Do I need to buy some extra electronic parts? Calling to all airplane guys....
Regards
Paul
ray schrauwen
03-05-2013, 11:08 AM
I had a friend ask me once if he could get or make a radio for a PT109 so he could independently control each motor as the real ones did.
The only solution I could think of was to use the guts from a 4 channel radio using 1 channel for rudder and the other 3 for individual motor speed control.
I say use the guts because It would be best for him to make the TX box himself sort of like an ACE radio. You could use 3 sticks from other cannibalized radios for each channel to control motors and either a 4th stick (or steering wheel) for steering.
It's just a matter of getting into it and doing it.
Yours would be slightly easier but, you say you want it to mix with rudder. I'm just not that well versed in mixing to help you with that.
Rocstar
03-05-2013, 11:23 AM
Paging "Srislash".... he has some info on this subject.
rabosi
03-05-2013, 11:25 AM
Some asked this on another forum recently. Check out this video using elevon mixing on the radio.
http://www.youtube.com/watch?v=cok0wJTJVLE
siberianhusky
03-05-2013, 12:29 PM
Not sure how on that radio, but it's pretty easy to do it with a Spektrum, can even assign it to a switch so you can turn the mixing on and off.
Looked at that radio at one point, did some research. There is a website with a ton of custom firmware upgrades and info about how to write your own.
Didn't bookmark it but it shouldn't be hard to find. They also sell the programmer, you need to modify the radio to do it though.
It really depends on how easy it is to assign the controls to different outputs on the rx and how to mix them. Didn't watch the video but you may be onto something on the elevon mix.
But it is possible!
785boats
03-06-2013, 03:45 AM
Here's the manual for it There are mixing settings in it.
http://www.hobbyking.com/hobbyking/store/uploads/1029023075X407290X49.pdf
mtbenjamin77
03-06-2013, 08:38 PM
On my Flysky IT4 I have a mix setup where dual motors are controlled with the trigger, then when i turn the wheel one motor slows down based on how much steering input I add. If I don't use the trigger one motor goes forward the other goes backward
srislash
03-06-2013, 09:13 PM
I have the exact gizmo for this situation
http://www.youtube.com/watch?v=CCxAs3tXVwY&list=UUWawdCx9olU1ShGOUMYJKNg&index=7
paultbg
03-07-2013, 09:10 AM
guys, thanks to all for your contribution.
@srilash - can you let me know what exactly is that mixer and where I can find one?
Regards
St3alth_Frenzy
03-07-2013, 09:35 AM
Would this work?
http://www.robotmarketplace.com/products/RL-IMX1.html
srislash
03-07-2013, 08:24 PM
Would this work?
http://www.robotmarketplace.com/products/RL-IMX1.htmlThe problem with that one is that it is either forward or reverse on each motor. The one that I had made has a potentiometer built in so that you can adjust the input on each one.You can slow one motor down alot or a little.I went thru hunting all over for this till Heyok said he could make me one.
Regards I have one here or I could have another made for you Paul. The one here never made it to its home in my FighterCat Shocker as it is resting at the bottom now.That was to be the gizmo's home. Let me know if you want one.
paultbg
03-08-2013, 02:34 AM
I think this one is similar:http://www.ebay.co.uk/itm/111019715056?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
@srislash-how much will be one from you?
Regards
srislash
03-08-2013, 09:19 AM
RegardsI paid Heyok $50 for mine. I can ask him what he would do another for.It may be better as this one was a one off.But this is a hand made item not a chinese knock off "one of a million" kind of thing. That e-bay one would be like the robot one I imagine.Interesting though. I didn't think of it but one could just go rudderless with one of these.Could be good for SAW use.
srislash
03-08-2013, 09:29 AM
I got an e-mail off to him Paul.That e-bay one would do it for your scale project though. Give me a bit to chat with Heyok and see if he'll be able to do a few at a better price.There has been a few interested parties but $50 scares them off.I paid it because of the design work and such for a one of a kind.
srislash
03-08-2013, 11:57 AM
Would you be looking for reverse as well Paul?
paultbg
03-08-2013, 12:21 PM
Well, reverse will be a nice addition.
Regards
Gusmoyer11
08-28-2016, 02:07 PM
Are these still around? Im looking at setting up a tug and will need the mixing
srislash
08-28-2016, 04:18 PM
I still have mine Gus. No home for it so you're welcome to it if you can put it to use. It does not control each motor individually but in conjunction with rudder input. I have tried it but it is a real fine line to adjust for a fast boat. I think for FE you would only need the upper 80% adjustable rather than the full spectrum. Likely fine in a tug where exaggerated adjustment may actually be needed.
Gusmoyer11
08-28-2016, 04:24 PM
I just found a 47mlb kit so it may go in that. How much do you need for it?
gsbuickman
08-30-2016, 02:48 PM
you might also find this useful, I started this thread on 4 channel mixing for adjustable trim tabs a couple 3 years ago.
http://forums.offshoreelectrics.com/showthread.php?44191-channel-mixing-for-adjustable-trim-tabs-on-th-fly&highlight=
785boats
08-30-2016, 06:14 PM
Paul.
As you can see by a few posts on here, you don't need any extra mixing units.
All the mixing that you wish to do can be done within the radio that you linked to in your first post.
No need to over complicate it.
Dashunde
09-07-2016, 09:03 AM
Before introducing a steering/throttle mix... I'd suggest getting your steering trim mechanically zeroed (using the linkage) so that your radio only requires a click or two in either direction.
If it were to need several trim clicks in either direction the mix might cause one of your esc's to not arm when the battery is connected.
