View Full Version : bby carbon outrigger
ktmakias300
02-25-2013, 02:24 AM
since last april randy send to me a fantastic outrigger but me i have a lot of bad luck and since then i never put it on water...
the plan was to play in 8s but the boat was very heavy and i had to go on 6s with another motor..... i wll put some pictures and a video later this week....
thank you randy for this fantastic boat i will make you very happy believe me
RandyatBBY
02-27-2013, 03:18 PM
Keep at it, I am glad you are happy I am building a twin now for me I have been working on it for 1.5 years.
ktmakias300
02-27-2013, 04:46 PM
randy i am going for a test drive on saturday .... i will make a video.... now i am building a twin motor outrigger.... if you see it you will love it
RandyatBBY
02-27-2013, 05:04 PM
Cool we are both doing it! I am sure there is a lot of other people building Twin riggers I am keeping mine under 34 inches running twin 4S setups.
http://img692.imageshack.us/img692/9369/0001bh.jpg (http://imageshack.us/photo/my-images/692/0001bh.jpg/)
http://img189.imageshack.us/img189/2931/0002ai.jpg (http://imageshack.us/photo/my-images/189/0002ai.jpg/)
Uploaded with ImageShack.us (http://imageshack.us)
ktmakias300
02-27-2013, 06:07 PM
xaxaxaaxa nice randy !!! you put 2 riggers together? very good and very funny!!!
i am building a prototype and is a very aerodynamic hull...you will see...4s isn t enough for this hull.... i will prefer you go for 2x 6s and lower kv so that you put 50 diametre propeler.the sponson you make is very good but the is one problem with that hull....the wide of the it will cause a large amount of air going under the hull so the back flip it s very easy to happen....
RandyatBBY
02-27-2013, 06:29 PM
I moved the aerodynamic lift back so the boat will not blow over so easy. The other boat was good to 98mph
ktmakias300
02-27-2013, 08:31 PM
my good friend i have an advice for you.... the gold rule of aerodynamics vehicles is the air you put in the roof of your boat must be 60% more than you put at the bottom....and always i am talking for speeds 100+ mph......use aerodynamics simulators programs for testing your shape....you will be more accurate and you will go more fast than you expect
Richie the shipwright
02-27-2013, 10:34 PM
Easy fix.... Put more aero downforce on the sponsons....??
Looks really cool Randy, I got faith in ya, you never know if something will work or not if you dont try it. With twice the power...you might need to paint twice as many flames on this one tho mate!! :-)
RandyatBBY
02-28-2013, 12:34 AM
:biggrin:[QUOTE=Richie the shipwright;487402]Easy fix.... Put more aero downforce on the sponsons....??
Looks really cool Randy, I got faith in ya, you never know if something will work or not if you dont try it. With twice the power...you might need to paint twice as many flames on this one tho mate!! :-)[/QUOTE
Ya I really have more worries about the ESC's than the hull design work I do and a wild paiting always makes it faster :biggrin:
borgie
02-28-2013, 05:16 AM
randy i,am designing my own hydro and i dont know how long the sponsons should be how do you work out the length of the sponsons
RandyatBBY
02-28-2013, 12:54 PM
It depends on application and type of water I am planning on running on. What you have so far?
Brushless55
02-28-2013, 12:58 PM
there are 2 people in my club who would be interested in this and possibly 3
1 is me :biggrin:
ktmakias300
02-28-2013, 02:05 PM
this boat is very beautifull randy !!!!!!
RandyatBBY
02-28-2013, 02:10 PM
1 is me :biggrin:
Let me get mine built then we will talk. One mold left to do.
RandyatBBY
02-28-2013, 02:12 PM
Thanks
RandyatBBY
02-28-2013, 03:34 PM
well that foilSim program is interesting it did tell me a little hint, Now I need to work it more.
94430
ktmakias300
02-28-2013, 04:05 PM
go for it randy i believe in you
Brushless55
02-28-2013, 08:29 PM
Randy, I talked with someone else today and now this may make 4 of us :biggrin:
twin PSpec power could be a hoot!
Mike Caruso
03-01-2013, 09:05 AM
94430
Which version of FoilSim? It is just what I am looking for. I started with Beginner it is very cool.
Thanks Mike
RandyatBBY
03-01-2013, 09:43 AM
Thanks Mike
http://www.grc.nasa.gov/WWW/k-12/FoilSim/index.html
ktmakias300
03-01-2013, 03:58 PM
my friends i respect your big experience in boats but some things must be checked from some programs like that....this is going to make you think about some things that you maybe never have thought in the past.......keep going
ktmakias300
03-05-2013, 07:14 AM
here some pictures
9476794768947699477094771
ManuelW
03-05-2013, 11:15 AM
shape of the rigger looks awesome. But thrust me, you can almost completely forget the results of foilsim for our application. Its pretty precise for a free flow over and below the foil, but in our application we run these very close to the water surface and ground effect has a major influence which changes everything. If you use a simulation software where you can take that into consideration and adjust the heigth of the foil above the ground, then it makes sense!
regards,
Manuel
ktmakias300
03-06-2013, 02:35 AM
i am totally agree with you manuel.and i have adjust the height of the foil above the ground and i think i am 70% correct to my results. i have a lot of research to do but i think i am going to have a good result....
ktmakias300
04-03-2013, 10:20 AM
first test on the water with small propeles
http://www.youtube.com/watch?v=8VRQz-PHPRI
RandyatBBY
04-03-2013, 12:53 PM
Water looked rough, but good start. Got any pictures of the boat set up?
ktmakias300
04-03-2013, 01:45 PM
thank you randy for everything ...here some pictures 9664996650
ktmakias300
04-16-2013, 11:13 AM
second run with my outrigger from randy!!!!
http://www.youtube.com/watch?v=DgKS_8kpAig
