View Full Version : WTB Proboat Mystic Strut
JimClark
02-18-2013, 08:15 PM
Looking for a like new Mystic 29 strut
lenny
02-18-2013, 08:31 PM
Hey Jim,
I hear they do not hold up good and should be replaced with something better.
Mine is very loose to and the boat is almost like new other than that,
I will be replacing mine to soon.
JimClark
02-18-2013, 08:34 PM
My boat came with a speedmaster but the PB stuffing tube appears to be an oddball size or maybe metric and it is loose going into the strut
lenny
02-18-2013, 08:53 PM
Ok yes,
Darin Jordan had to make a spacer when he did his.
Some info hear on it.http://forums.offshoreelectrics.com/showthread.php?17514-Miss-Geico-Race-Prep
Also hear in the beginning posts second page to.http://forums.offshoreelectrics.com/showthread.php?29976-Your-MG-that-started-off-as-a-hull
G.Rose
02-19-2013, 09:07 AM
I had a slight gap between my stuffing tube and my strut. I put a piece of brass in to the strut then measured the gap to the white stuffing tube. The brass almost fit over the metric brass tube from the boat. I took a phillips screw driver to stretch the brass piece in the strut to fit over the metric brass tube. I hope you can do the same.
lenny
02-19-2013, 09:21 AM
Hey Gary,
What strut are you using on the boat ?
G.Rose
02-19-2013, 09:25 AM
Not a speedmaster. I had an old one out of made out CF w/ a flat bottom. I adapted it to the boat. I am testing this morn. If it doesn't work I am going to an old octura strut w/ a small skeg.
lenny
02-19-2013, 09:51 AM
Ok thanks for that info,
Have you been running and working with these hulls long ?
JimClark
02-19-2013, 02:32 PM
anyone have a junk strut that still has the nose cone on it?
JimClark
02-19-2013, 04:48 PM
found a solution I can make a new nose piece that will fit into my speed master strut by using this K&S tube
93967
I just need to drill it out to .240 and it will fit perfectly over the metric stuffing tube in the PB Mystic
BHChieftain
02-20-2013, 11:46 PM
Was this a stock Mystic? I have a new Miss Geico and wanted to ditch the plastic liner and was wondering what size flex and strut to use...
Chief
JimClark
02-20-2013, 11:57 PM
the flex is .150 I am replacing the stuffing tube so it will fit the speedmaster strut that came with the boat I bought
lenny
02-21-2013, 12:05 AM
Hey Jim if you do not need the strut any more,
I still need find something for mine.
Chief let me know if Jim does not need it.
JimClark
02-21-2013, 12:19 AM
I don't have the stock strut only the speedmaster that came with the boat and I am using that.
This is what I have http://www.offshoreelectrics.com/proddetail.php?prod=ros-21-strut
Jim
Darin Jordan
02-21-2013, 09:13 AM
Jim, if you can make it work with the Speedmaster strut, you'll be happier. The bearing material in the stock struts doesn't hold up very well, and is a little sloppy.
That said, I bore my stock struts out to .250" and install Lead-Teflon bushings, and then the world is all good! :) Pretty simple to do and everything else fits as designed....
lenny
02-21-2013, 09:26 AM
Hey Darin, :tiphat:
Where can I get the bushing to do that to mine ?
Also any trick to fix the sloppy rudder on it as well ?
Thanks for any info on it.
JimClark
02-21-2013, 02:16 PM
I am definitely replacing my stuffing tube only decision remaining is Teflon or no Teflon. I can see it now I bore a proboat strut out to fit the octura bushings then get in a wreck and the stuffing tube gets damaged then It is difficult to find the right size of tubing.
Gonna fix it correctly the first time
Jim
