View Full Version : Aeromarine 43" Challenger pro gas to FE build
Spot Me 2
02-18-2013, 09:55 AM
Hey guys,
I have been out of FE for a little while, but due to too many noise complaints....no more gas running.
I recently picked up a 43" Challenger pro that was a gas boat. I am going to convert it to FE. I only do sport running and I am looking for scale-ish speeds mid 30s or low 40s.
I ordered an Atomik V700 Marine Outrunner (http://www.atomik-rc.com/V700-Marine-Outrunner-1100Kv.html) and a seaking 120 amp ESC. I will be running on 6s. I need help picking a prop. I only have big gas props. I know Atomik runs a 54mm 3 blade on their 58" cat with this set up. Is this a good place to start?
This is what I am strating with...
http://i60.photobucket.com/albums/h9/spotme2/challenger43_zpsc1a2b6c9.jpg
http://i60.photobucket.com/albums/h9/spotme2/challenger432_zps2a82724f.jpg
http://i60.photobucket.com/albums/h9/spotme2/challenger43-3_zpsb4e2f5a7.jpg
gyrotron
02-18-2013, 07:04 PM
Hello,
I just finished building a 41" boat which was designed for gas and made its conversion to FE. It was my first build but you may find usefull information equipmentwise and some other tips.
http://forums.offshoreelectrics.com/showthread.php?38209-DaVette-Aspect-Shallow-42-quot-Hull-New-Build-Motor-selection-and-misc.-help-needed
Good luck with your build!
Rumdog
02-18-2013, 08:16 PM
Fwiw, that is a VERY small motor for your boat. Venom didn't do the best job rigging their boat with gear.
Brushless55
02-18-2013, 09:02 PM
agreed...
Jason4636
02-18-2013, 11:02 PM
I agree with the above post.
Go to southriver rc and get you a good 5" motor mount. That's what your rails look like. And get you an inrunner motor some thing in the 56mm diameter. And something with a kv in the 8s area would push that boat great
Spot Me 2
02-18-2013, 11:51 PM
I here what you guys are saying. I'm not looking to set the water on fire. I am trying to use what I have already. If its too slow I can always upgrade. I was thinking of a proteus x524 if and when I do.
Brushless55
02-18-2013, 11:57 PM
a slow running boat is a wet running hull
wet running hulls pull lots of wasted amps.... = heat
and a hull this size, well ....
and the motor from venom is marked up about 3 times
Brushless55
02-19-2013, 12:04 AM
The Proteus 56MM motor was only about 10bucks more with possibly 4 times the power
http://www.offshoreelectrics.com/products.php?cat=Proteus+Motors
the Leo 5692 1340 motor could be run on 6s like your after and with more power than the venom
Spot Me 2
02-19-2013, 12:26 AM
I didn't pay that for the motor. I paid $50 shipped for a brand new one. Maybe I will just use it in a different boat cause I just ordered a Proteus 520 (http://www.rcecho.com/SKYRC-Proteus-Water-Cooled-X520-730KV-1280KV-Brushless-Motor-for-Marine-IM680.html) and a southriver mount. That should run on 6s with room to grow. Now, on to the prop. Whats a good place to start?
gyrotron
02-19-2013, 12:53 AM
Here is a quote on props. for this size of boat from fellow boaters:
"Probably up to 65mm 2 blade max. You could try a X457, X460, X462, X465, X460/3"
I will be running on my 42" boat a 52mm and a 59mm for starters.
Jason4636
02-19-2013, 01:10 AM
With the proteus 520 depending on what voltage you run it on. Of not start any higher than p 55or60mm prop
lenny
02-19-2013, 01:26 AM
Nice looking boat, :tiphat:
I have that v700 motor,
And want to try it in my 36"pro boat shockwave modded to FE.
Spot Me 2
02-19-2013, 08:33 AM
I am still planning on just 6s. I already have those and the esc can only handle 6s. My plan it to run it on the delta/1280 setting.
Brushless55
02-19-2013, 10:53 AM
good job, and looking forward to seeing this one run!
Spot Me 2
03-01-2013, 02:49 PM
I got the motor and motor mounts today.......time to get busy!:w00t:
Brushless55
03-01-2013, 06:10 PM
Pictures!!
Spot Me 2
03-01-2013, 09:16 PM
Pictures!!
A little progress has been made. The aluminum tray in the back will not be there. It is just sitting there to hold up the esc right now.
http://i60.photobucket.com/albums/h9/spotme2/DSC_0047_zps3fe2663d.jpg
ray schrauwen
03-01-2013, 09:25 PM
You running 6S or more??
Spot Me 2
03-01-2013, 09:28 PM
6s for now......... plenty of room to go bigger later
gyrotron
03-02-2013, 09:40 AM
Hello Spot Me 2,
Did you cut the motor shaft? If so how much?
Thx
Spot Me 2
03-02-2013, 12:02 PM
Hello Spot Me 2,
Thx
Nope. I left it alone.
jcald2000
03-03-2013, 07:56 AM
That to much free flex showing, 1/2 " is what your going to need to keep from balling up the cable.
Spot Me 2
03-03-2013, 08:42 AM
Well thankfully there are multiple holes from running different gas setups with and without clutches so moving it back is not a big deal. I will have to drill new holes for the front of the mount. This is the next hole back. I think it will work just fine.
http://i60.photobucket.com/albums/h9/spotme2/DSC_0049_zps8a679a8b.jpg
lenny
03-03-2013, 10:31 AM
Looks good,
Or you could flip the front mount over to in the hole it was in.
But not sure looking at it from hear.
The water jacket looks better like that to,
Just make sure to run the in water line to the lower jacket nipple,
And the top nipple for the exit flow.
jcald2000
03-04-2013, 07:12 AM
Just make sure the flex goes straight into the tube with out touching it. You might have to slot the tube holding crossbar and adjust it.
Hor2012
03-08-2013, 10:58 PM
This is one of my boats same just 48" 5s2p
lenny
03-08-2013, 11:34 PM
Looks nice,
Did you get it wet yet,
Also what is the hull in the back ground ?
Hor2012
03-08-2013, 11:37 PM
Looks nice,
If the question is for me. Lol. It's also a aero marine. Avenger 48". I had them since last year just doing new paint jobs for the summer
Hor2012
03-08-2013, 11:39 PM
Closer look
lenny
03-08-2013, 11:43 PM
Yes,
The bow looks very cool,
What does the hatch look like for it.
I need to do some painting to some day.:thumbup1:
Hor2012
03-08-2013, 11:55 PM
This is the only pic I have on my iPad of the hatch b4 the boats were painted
lenny
03-09-2013, 12:29 AM
Ok,
I still need to put this 48"one together.
94963
And paint this one.
94964
ray schrauwen
03-09-2013, 08:23 AM
5S2P?????
Are you running a Castle or Sirius 1717???
Hor2012
03-09-2013, 09:04 AM
Sorry I run. 2 5s packs. Making it 10s
Spot Me 2
03-17-2013, 08:26 PM
......and now, back to the build............
I need help picking a prop for this bad boy. I have everything ready to run her except a prop. I have a back cut 3 blade gas prop that is 62mm. Is that too big to start with with this set up?
lenny
03-17-2013, 08:39 PM
I would start with a x452 and see what the does for temps and running.
03-17-2013, 09:42 PM
I agree with Lenny about starting small, although the 52mm may be too small to plane well. You'll just have to try it. That motor should handle a 55mm to 58mm prop, but a 62mm 3-blade would be a stretch. Start small, run for one minute (timed!), bring it in to check temps, send it out for another minute, etc. This takes time to do but with your setup and virtually no experience by others it is the safest way to proceed.
