View Full Version : ESC QUESTION, Hifei Swordfish PLUS 200 amp
Mecka1990
02-06-2013, 09:29 PM
Hi,
someone got the listed ESC like me and can give me a detailed information?
when i give full throttle, what color and how the esc flashs? mine blinks green every 0,5 seconds with full throttle, i think i read somewhere that it must be red and constant with full throttle, is that right?
drwayne
02-07-2013, 08:48 AM
solid green
turn the throttle adjust on transmitter to 120% and try again.
some 2.4ghx Tx do not calibrate SF esc properly...
DocW
Mecka1990
02-07-2013, 01:01 PM
solid green
DocW
i tryd, still flashing green every 0,5 seconds, set my spektrum to 125% throttle, tryd to calibrate the throttle endpoints new, esc new calibrated, still the same, hmmmm
drwayne
02-07-2013, 05:36 PM
on spektrum, set throttle to 100%
Calibrate esc again with this Tx setting.
-- turn on Tx.
-- hold throttle 100%
-- turn on esc.
-- "music" dling dling dling dling .. pause beep beep ..pause.. beep beep .. pause ... beep beep ...
-- somewhere in middle of 2 beeps ( pause ) you release throttle back to zero
now adjust Spektrum throttle to 125%
try again.
DocW
Mecka1990
02-07-2013, 09:17 PM
-- turn on Tx.
-- turn on esc.
try again.
DocW
thats what i have done, hmmmmm
maybe the esc dont get enough power? 37mm 2075kv dwind, twinsetup with 5s 80c 4000 mah
Mecka1990
02-07-2013, 09:21 PM
latest firmware for ish 200+ amp i get from hifei.com via skype, before 3 days, so the firmware isnt the problem
Mecka1990
02-11-2013, 09:25 AM
-- turn on Tx.
-- turn on esc.
try again.
DocW
got a vid for you, help me getting this stuff runnign corectly haha, i have no idea what to do. just uploading...
Mecka1990
02-11-2013, 09:34 AM
so, here it is, on the first vid you can see i hold the throttle on the transmitter on 100%, connecting the esc with lipo, no 2 beeps with pauses between, hahaha, whats next?
i tryd: spektrum 100% th settings, set esc with the first 4 beeps, not solid green with full throttle (as you can see), set throttle 125%, still not solid green, but a little bit more power.
1. vid esc settings with weird sounds:
http://www.youtube.com/watch?v=UjfgrdrXW3o&feature=youtu.be
2. Spektrum dx20 125% throttle:
http://www.youtube.com/watch?v=xLdx8wNEnJk&feature=youtu.be
im getting frustrated :help:
Mecka1990
02-11-2013, 09:44 AM
and yes i set the esc´s first with 100% spektrum throttle settings and after setting them i change to 125%, i tried 125% first to and then tested, not working.
lipos are fully charged for the tests.
still same esc settings like lvs, startup, and the rest
Mecka1990
02-11-2013, 08:10 PM
as you can see on the first vid the leds are only flashing with full throttle
when setting up the esc´s i tried to realese the throttle after the first period of beeps and this funny sound, but when i do so it starts again, i tried to realese, press, realese, bla bla, when i realese it with the 5. beep, it starts 5x beep, funny sound, and again beeps till 10.
drwayne
02-11-2013, 08:29 PM
in video #1
you need to release throttle at 0.19 or 0.20 or 0.21 !
there is one beep ... beep ... beep ... beep !
not 2 .. have not heard this routine before, but means same.,
W
Mecka1990
02-11-2013, 08:30 PM
thats what i did, hmmmmm, any other ideas?
Mecka1990
02-11-2013, 08:45 PM
i try today the traxxas transmiter when i get home, this poo must works -.-
drwayne
02-11-2013, 09:05 PM
what usb setting for this esc ?
Mecka1990
02-11-2013, 09:10 PM
lvc: 5cells (tryd already 2 cells lvc, maybe lvc was on, wasnt)
Startup: standart (tryd soft and fast, fast startup is not good because he jumps from 20% throttle instantly to over 60% and he is screaming, dont want my boat try to fly)
pwm rate: 8 khz (tryd 12 and 16)
timing: auto
Cutoff Voltage/Cell: 3.1
Brake Types: no brakes
Cutoff Type: Hard Cutoff
Mecka1990
02-11-2013, 09:15 PM
i got a traxxas XO-1 and will take the receiver and transmitter to test it on the esc´s, there is definetly something wrong, 6 months im searching for a reason why this crap wont work, everythign done what is in my possibility, maybe tomorrow it works ;(
Mecka1990
02-11-2013, 09:17 PM
with the last drve of my zonda i get only 34 km/h, lvc was off, 39mm props on 2075 lv dwind sss 37mm motors with 5s, thats really not ok ;(
Mecka1990
02-12-2013, 08:59 AM
so, i tryd today 3 different transmitters, 1,5 hours working on this and i cant set the esc´s for 100% throttle, i tryd everything that is possible, still not solved, i writed a mail to hifei, lets see what they say to this.
drwayne
02-12-2013, 09:02 AM
When you use USB it will show the throttle range setting. if this is more than 700us it is 100%....
China has Chinese New Year holidays now.. every one is closed until maybe 20th !
This is most strange
1. does your Rx use power from esc ? I would try outside Rx battery ( use USB to turn of Rx power from esc )
I hear the esc play tone for 4 cells in video #1
You have set by USB to 4cell ?
Set by USB the timing for medium.
very unusual for 2x esc same fault..
cheers
W
Mecka1990
02-12-2013, 09:05 AM
ah thats right, i will try to connect the esc´s with usb again
Mecka1990
02-12-2013, 10:34 AM
Only 512 throttle range, what now?
drwayne
02-12-2013, 10:44 AM
2am here.
Let me sleep !
Maybe I dream of answer haha
Mecka1990
02-12-2013, 11:17 AM
HAHAHA, yesterday i writed and workd on the boat from 22 pm till 7 am, and yes i was here and writed everything ;) good night, hahaha, i hope you find a answer :p
Mecka1990
02-13-2013, 08:24 AM
drwayne, got a screenshot for you.
93649
you can show me yours? or someone others can show me that he really get 100% throttle?
Mecka1990
02-13-2013, 08:32 AM
and this one is the second esc:
93650
whats now wrong? -.-
Mecka1990
02-13-2013, 08:43 AM
i tryd now the traxxas TQI and the second both ESC got the same Parameters like before, nothing changed...
drwayne
02-13-2013, 08:57 AM
here is SF200 on 4S.
I think your problem is somehow Tx/Rx.
93651
Mecka1990
02-13-2013, 09:00 AM
what exactly you mean with Tx/Rx?
Mecka1990
02-13-2013, 09:27 AM
SOLVED, i get it, finally, i needet to set my spektrum DX2.0 on 75% throttle, then i Setted up the Esc: 3 beeps when plugin in with holding Throttle Max forward, then comes 1 beep, pause, 2. beep, pause, 3. beep (release).
after that, i give full throttle to record the data for the data logger, with about 20% throttle i change on the transmitter from 75% to 125%, and then i get the 100% throttle.
oh man, that was a hard job, about 3 months working on this -.- (not all the time, every week 2-3 times)
screen 1 = Esc on the Right side
93652
screen 2 = Esc on the left side
93653
how you can see the motors are working a little bit different, shoud i see that when driving in water?
