View Full Version : how to de-lift a prop
drwayne
02-03-2013, 02:32 AM
How to remove lift from Octura X4 and X6 series. ?
Thx
W
TristanJones
02-03-2013, 03:02 AM
wrong link... I'll try find the right one, it explains all you'll need to know to have a go at it.
TristanJones
02-03-2013, 03:10 AM
try this...
http://www.rcraceboat.com/Propcuttingpage.html
hope it helps.
wayne middlemiss
02-03-2013, 03:11 AM
cup the leading edge
TheShaughnessy
02-03-2013, 03:14 AM
Back cutting should do the job. You can also try rounding the tips a lil and cupping too. It condenses the thrust cone so should help with lift
capnswanny
02-03-2013, 03:46 AM
:confused2:
I'm pretty new at this, but I thought de-tounging was a biggie for removing lift, while also lowering torqe and increasing RPM.
Is it the back cut that is more critical to lift reduction??
drwayne
02-03-2013, 05:00 AM
Ive spent the last 45 minutes searching through their blogs for part2 !!!!!
Grrr.
:smile:
Xzessperated
02-03-2013, 05:12 AM
Grrr.
:smile:
Talk with Chuck.
TristanJones
02-03-2013, 05:56 AM
use the search bar and type in prop school.
The other link (the right one) pretty much tells you what to do and where mate.
drwayne
02-03-2013, 06:10 AM
haha .
original link vanished :lol:
TristanJones
02-03-2013, 06:47 AM
yeah I took it down.
Here...
try this,
http://www.mercuryracing.com/blog/?s=prop+school
egneg
02-03-2013, 08:47 AM
:iagree:
Cup the last 3rd of the leading edges and round off the tips a bit.
02-03-2013, 10:27 AM
I have had the best luck doing what egneg suggests. The goal is to reduce the diameter of the 'end' of the thrust cone, producing a more narrow cone. With a surfacing prop, a wide thrust cone directs more water in a downward vector, lifting the transom. By reducing the cone's end diameter, more of the water is directed parallel to the pond surface and less downwards = less lift. Cupping the leading edge slightly will keep the water on the blade longer instead of slinging it off sooner. Keeping it on the blade narrows the thrust cone.
Some have had luck with "back cutting" the prop's trailing edge, but there are different ways to "back cut" - some of which do little for lift. Some methods will reduce overall thrust, which of course reduces the lift too.....
drwayne
02-04-2013, 07:53 AM
Thanks for your assisting comments above... aids my understanding of prop work.
Have dremel and pliers at the ready ..
egneg
02-04-2013, 08:32 AM
Pliers will do in a pinch at the pond, but cupping balls are the preferred method.
93168
drwayne
02-04-2013, 08:40 AM
Yes.
I just couldnt say that in front this male audience :lol: :tape:
egneg
02-04-2013, 08:44 AM
Yes.
I bet Andy would let you cup his balls. :drool:
drwayne
02-04-2013, 08:46 AM
You're a very sick man .
:lol:
egneg
02-04-2013, 08:52 AM
:lol:
He has beautiful cupping balls though. :blush:
