View Full Version : Centurion Minni Cat
TristanJones
02-02-2013, 07:25 PM
Hi guys n gals,
Has anyone on here had a play with one of these hulls performance wise??
I've been trying different setups in mine, and I'm currently running a HK donkey motor which is a upgrade in both physical size, and KV from 3000 to 4200kv. I'm still using a 30A ESC which seems to be up to it so far, It gets a little hot so Ive got a 50A on the way. Ive got a HK alloy CNC 32mm prop on it which I'm liking so far.
I am yet to measure the top speed but I will carefully estimate 80km/h. Way way way faster than the stock motor, punch the throttle and it explodes in a mist of white water and noise as it disappears over the lake. Much fun!!!!
It took a bit of stuffing around to get the motor mounted and I had to order a water jacket to suit, but at the end of the day pretty darn easy and very much worth it!!
I'll get some video up in the next few days.
bikergreen
02-03-2013, 02:14 PM
I have one and its great fun to drive, once you get the CG right. I didn't really think about upgrading it as I think it runs pretty well stock, I run a 32mm back-cut prop. I am interested to see what motor you put in it and a run video though, might have to upgrade after all. Mine is currently getting a new look.
TristanJones
02-03-2013, 02:55 PM
I saw your thread, it looks awesome man!
Im running a similar prop, with this motor upgrade Id say by eye its almost twice the speed, though I had to make a collar to go around the bearing carrier at the front of the motor so I could flush mount it. I used 2 washers that I cut up as needed with my dremal and they work fine (took me 5mins). I had to get a 380 size cooling jacket, I recommend the silicone one from kintec as its a tight fit and the plyability of the silicone is useful when fitting everything back in. Also I recommend using a 50amp ESC.
http://www.hobbyking.com/hobbyking/store/__21972__HobbyKing_Donkey_ST380L_4200kv_Brushless_ Inrunner_Car_Motor_11T_.html
http://www.hobbyking.com/hobbyking/store/__24568__HobbyKing_50A_Boat_ESC_3A_UBEC.html
I need something to do today so I'll get some pictures and if I get to the water, I will take my camera and get some footage and put it all up in this thread (it doesent warrant a build thread). I haven't seen any on youtube that have been modded and I understand why, they are very much a toy boat, but lots of fun none the less!!
bikergreen:
Are you still running the stock ESC?
Have you needed to replace the flex and drive shaft yet? If so where did you get one?
Does yours leak much water? (mine leaks like a siv)
bikergreen
02-03-2013, 05:05 PM
That looks like a good little motor - Mine is totally stock, the only thing that bugs me is the collet. It doesn't sit totally strait when its screwed down and causes vibration and noise. I could see wanting to upgrade the flex drive along with motor and collet for a wicked set up.
Mine doesn't leak, I put lots of grease in the strut and tape the hatch and hole for the antenna as I don't use it. Good to get it sealed as I flip it all the time lol. I don't know if I need it faster though as I almost never have glass flat water to run in.
bikergreen
02-03-2013, 05:21 PM
Maybe at some point one of us will do this:
http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc098L-24c
http://www.offshoreelectrics.com/proddetail.php?prod=ose-80046
http://www.offshoreelectrics.com/proddetail.php?prod=etti-a007
Might require a new stuffing tube
TristanJones
02-03-2013, 05:24 PM
Ive ordered a compression coupling for mine I've only had too replace the flex drive twice so far, from damage caused by running it in reverse (was at 25% to get unstuck from the weeds on the opposite bank of the river). Ive since disabled reverse and drive more carefully.
I had a lot of problems with mine being upside down when I go it, not so much now, but you do have to be careful. I was running mine in pretty much the same conditions as the video below. The boat is 100% factory issue in the video, battery is 3s 2650mah 30c
http://www.youtube.com/watch?v=pjBbLQ_6H3A
TristanJones
02-03-2013, 05:34 PM
That looks like money well spent to me..... thanks for putting that up, saved me looking through and finding the items. After I get some run time n the set up i will give it some thought, there are plenty of other suitable motors available.
Imagine 2x2s 2200mah 550 size heli batteries in series (4s), they would fit in it and be great balance as could fit in the front of each sponson..... the rudder is obviously already side mounted so with the bigger shaft and hardware could maybe go up to a 38-40mm prop!!
I think you could possibly make one of these do over 60mph........ (seriously thinking about trying it)
bikergreen
02-05-2013, 07:25 PM
I'll probably wait until I break something to start up grading, I do like how it has bearings in the strut already. Maybe you can just use the OSE flex in the stock strut with the bearings. My boat already sits low in the water.. 4s would be nuts! but funny to try lol.
TristanJones
02-05-2013, 07:41 PM
I'm on my second flex/drive shaft and now 3rd ESC (will be upgrading to 50A this time).
Ive got too many projects on the go right now, Once I get the 50A ESC, get the genesis running over 62mph, upgrade the rx7 to BL and upgrade driveline/suspension accordingly, finish off my new 31inch outrigger.
Then I will look at going silly on this thing, the 550 size heli bats are really small and light they will fit in the nose of each sponson, but might ruin the COG completely, my mates got a few laying around I can try.
I can see this little boat being heaps of fun, when I get the new ESC I will shoot some footage of how it is now and throw some pictures in this thread of the upgrades. Might even put my GPS in it, but it adds a fair bit of weight.
bikergreen
02-05-2013, 07:46 PM
ya sounds good - I will be swapping out my ESC also as I have one coming and will use the 30A one in the jet boat I'm building. I never put my GPS in mine last summer. I will when its running again, my GPS is really small. Can't wait to decal up and do the final clear coat on my hull!
TristanJones
02-05-2013, 07:50 PM
I look forward to hearing how you go performance wise.
I also look forward to seeing the pictures of yours all finished, so far its looking unreal!
bikergreen
02-05-2013, 08:05 PM
Getting the decals custom made as we speak! Hopefully have all the little sponsor decals also!
TristanJones
02-08-2013, 12:54 AM
Nice one!
HK have just got spare flex drives in stock, I suggest you grab at least one spare, it took 4mths for these to come back into stock.
bikergreen
02-08-2013, 03:23 AM
Nice one!
thanks for the tip!! I have never looked. just did a blood HK order last week :( fail
TristanJones
02-08-2013, 05:04 AM
they only came into stock today, been 4mths out of stock, grab one anyway! they are about $5
I had to track one down, from Europe, was $30 delivered....
bikergreen
02-10-2013, 10:04 PM
Thats annoying.. I ordered a couple and some other small items so I should be set.
TristanJones
02-10-2013, 10:07 PM
good idea! happy boating!!
I ordered the new 50a esc and some other bits today so hopefully its going again this week.
Mattwarner
03-07-2013, 05:05 PM
What's the verdict on this as its currently in my cart but not sure whether to take the plunge! I've got a pair of 2200 3s packs in storage so looks like this would be ideal
TristanJones
03-07-2013, 05:52 PM
Its a great little boat to start off with I think, I still enjoy running it and Ive moved up significantly since. Id buy it again.
RE: Using the 4200kv donkey motor on 3s makes the thing an absolute rocket, it definitely needs the 50a esc.
HOWEVER
It is a fair bit of stuffing around to get the motor to fit in place and stay there. With such high rpm the slightest imbalance anywhere causes monstrous vibration and seems to rattle the motor loose. Im currently debating weather to glue the motor in it or not.
I haven't had a chance to test this idea out well enough to recommend it or provide a how too. The motor temps were quite high if I remember correctly, but I believe that to be propeller related, just haven't had enough of a chance to try it out.
The nice expensive flex shaft and billet alloy prop are at the bottom of the river now so its got a farken huge 3 blade on it, and the stock motor back in it (a rubbish idea I tried for 1min and not since). Might charge a pack up glue the donkey motor in it and go for a run today, I can always file/cut down the blades on the prop till it works.
For ease of fitment and what i think would be a great upgrade motor Id use this...
http://www.hobbyking.com/hobbyking/store/__8594__2848SL_3900kv_Brushless_Inrunner_WaterCool ed_.html
Mattwarner
03-10-2013, 04:16 PM
I just want a cheap small boat to chuck in a back pack and run on small water, I've got a twin cat and a large mono for when I am being a bit more serious! just missed out on one on eBay although it as getting close to HK price so backed out
TristanJones
03-10-2013, 07:21 PM
Id grab one of HK, they hook along well for the size, they flip over easy but all round a great toy boat.
Is the hull fiberglass or plastic?
TristanJones
03-10-2013, 09:22 PM
mine is fiber glass
bikergreen
03-11-2013, 03:24 PM
They are super fun to rip around even in plain stock form with just a prop. I use a 432B
bikergreen
08-10-2013, 12:39 PM
Finally after lots of waiting around my Centuion got painted and I got to decal it and put it all back together!
http://i732.photobucket.com/albums/ww323/bikergreen/84DD908F-F1DB-4B1A-9EC9-29B9BB0D018C-14428-0000026524555596_zps26b17805.jpg (http://s732.photobucket.com/user/bikergreen/media/84DD908F-F1DB-4B1A-9EC9-29B9BB0D018C-14428-0000026524555596_zps26b17805.jpg.html)
http://i732.photobucket.com/albums/ww323/bikergreen/2FB0B57A-3CB5-4310-B6F9-BC7C0982A8B1-14428-000002651C7587A0_zps014d759b.jpg (http://s732.photobucket.com/user/bikergreen/media/2FB0B57A-3CB5-4310-B6F9-BC7C0982A8B1-14428-000002651C7587A0_zps014d759b.jpg.html)
guillaumeux
01-16-2015, 09:14 AM
Hello everybody,
I know that this post is 2 years old but I hope some are continuing to drive their boat.
So could you tell me where is the COG of this boat ?
What did you do to ameliorate the stability of the hull ?
My boat with my adjustments don't porpoise no more (pitch axis), but in not so rough water, at full speed, it rolls over : it starts to roll over each side very quick, and at last it rolls over on it back (it become unstable on the roll axis)...
My adjustments : I put my battery at the max (2200 mah) in front left of the boat and I push up the struts (a little more than the 0 level).
Thank you for your thoughts,
And sorry for my bad English, I hope you understood me ;)
chipgibbs
05-25-2015, 02:05 PM
Does anyone know what coupling to use on this boat to replace the stock grub screw type?
Thanks
CG3
