View Full Version : TRAXXAS 1/16 motor and esc in a mini mono.
Garrett
01-27-2013, 06:11 PM
Has anyone tried this yet?
bikergreen
01-27-2013, 06:40 PM
that motor is only rated to 25a constant - almost picked one up until I found that out, I don't think it will handle the load very well.
Garrett
01-27-2013, 06:45 PM
I've got this motor and esc in my RC air boat. But that's a different hull and characteristic.
bikergreen
01-27-2013, 07:42 PM
air boat is less load I would assume but could be wrong. I'm sure it would work if it was propped really lightly
Southwest
01-28-2013, 05:29 PM
The airboat has MORE load due to water surface of airboat compared to monimono. I would put a Leo 2550kv on 3s and a 432 octura prop. Now with using a high voltage makes it easier on esc and as a whole will run cooler. Car motors will use 2S voltage and not burn up. Just my 2 cents.
Garrett
01-30-2013, 03:05 PM
thanks, I'm still learning.
Garrett
01-30-2013, 03:14 PM
well, I hit up the local hobby shop, and bought a 40A ESC. it looked the same as the AquaCraft 20A ESC. And unfortunately it didnt fix my problem. it'll run for about 5 minutes, then stops. Its like the motor wont spin, or has a spot where it wont turn. hard to describe. Guess I should get an inrunner for it and quit messin with the outrunner motor.
Eyekandyboats
02-16-2013, 05:44 PM
Check your motor timing on that esc you got. Could be a issue. As out runners like higher timing generally
Sent from my iPhone 5
