View Full Version : what is the cell limit on sv27 esc
pugman2
06-18-2008, 11:10 PM
can i safetly run 2- 7 cell packs without toasting the esc? dont have any cooling issues whatsoever with props and motor now running hills ib 6 cell pacs would like to run 2 ib 4200 7cell packs
Ocean Racer
06-18-2008, 11:40 PM
from what ive heard you are fine but wait for some more advise to come along to ethier prove or disprove this.
H&MWill
06-18-2008, 11:52 PM
Yes 2 7 cells are fine but do away with BEC and run a seperate receiver pack.
hex-dj
06-19-2008, 12:35 AM
pugman 2... you can have 14 cells,but with a trick you can have 16 or 18 cells...with bec battery of course.
H&MWill
06-19-2008, 02:14 AM
As long as a couple of those cells are toast.
hex-dj
06-19-2008, 02:21 AM
(H&M) I agree...
i run 16 with out any problems, on its own reciver pack though
ETOWNE
06-20-2008, 12:06 AM
i run 16 with out any problems, on its own reciver pack though16 MPH that is.....lol
hex-dj
06-20-2008, 01:39 AM
Maybe he will do much better if he runs unparallel cell packs and unmatched cells,so that boat can be fully raceable...LOL
Apples1
06-20-2008, 02:10 AM
is that how it works , 1 cell per 1 MPH, thats an easy fix to hit 60.
i reckon i have 80 or so cells lying around lol
pugman2
06-20-2008, 09:24 AM
so i just plug a rec pack and switch in . and it overrides the other sorce ? or do i have to cut some wires
ghostofpf1
06-20-2008, 11:49 AM
Don't cut wires...two ways I do this
1) simply remove the esc's red wire socket from the plug and fold it back onto the wires and tape/heat shrink it in place
2) make an extension up that has the same thing done to it or has had the red wire cut off.that way you're not messing with the esc's plug
I've included a couple pics in case my words weren't clear enough
HTH
Ghost
cuzican
06-23-2008, 05:27 PM
If you don't mind me asking, why do you disconnect the BEC? I have been running 14 cells in my supervee without unhooking the BEC. Am I gonna ruin something or is that just a personal preference??
thanks
thanks
mine started glitching
SweetAccord
07-12-2008, 05:43 PM
thanks
The BEC inside a ESC can only regulate so much voltage that is connected by a battery by design. When you conntect more voltage than it can handle, it's not capable anymore, so glitching, heating, etc occur. So, you disconnect the red wire to not get this voltage and supply the ESC with voltage it can handle, hence the seperate battery pack.
Hope that clarifies.
Peace~
electric
07-13-2008, 10:33 PM
My crazy brother is running 16 cells with his SV27 and using the standard BEC to power everything. Strangely enough it all works and has not flamed out even with a great deal of use. Not advisable, but just thought it was interesting.
Sorry to bring this one back up. Is it still an issue to run 14 cells w/ stock SV27s?
Brushless55
05-20-2009, 06:42 PM
Wow!
16cells on a SV27, wonder what kind of speeds they get?
dr. hook
05-20-2009, 06:48 PM
If your gonna run 14 cells then run a castle BEC or a receiver pack.
LMAO @ 16-18 cells.
Good luck with that
Brushless55
05-20-2009, 08:54 PM
18 cells? oh my!
What is a castle BEC? I know what a receiver pack is.
Castle Battery eliminator circuit.
Castle is the make/brand
