View Full Version : HobbyWing Seaking 60 A acting strange?
paultbg
01-26-2013, 11:58 AM
Hello
I have the above Seaking 60A esc in a mini boat.From few days now, when connected to the batteries, is not detecting the right number of cells (3s) only 1 and is making only one beep.
Otherwise it seems to work ok. I have tried on auto setting and also setting manually the number of cells, still the same thing.
Any ideas? Maybe you have experienced this before? Please advise.
Regards
Heaving Earth
01-26-2013, 12:31 PM
Is it calibrated to the radio correctly?
paultbg
01-27-2013, 04:57 PM
Hello,
Yep,calibrated several times...still the same problem.Any other ideas?
Regards
bikergreen
01-27-2013, 06:00 PM
do you have a program box? It may have ended up getting changed from auto lipo detect some how..
paultbg
01-28-2013, 12:17 PM
No, setting are changed every time with only the radio...i do not have a box
Tx
martin
01-28-2013, 01:55 PM
Get you self a prog box anyway, best $10 you could spend.
MAMBA2200
01-28-2013, 02:27 PM
you must have the box its the only way to really know and there very cheap
paultbg
01-31-2013, 03:21 AM
Just a quick update to let you know that I found out what was the problem with my ESC.
When the LVC is disabled, the ESC is not counting the cells anymore.
Once I have set the LVC back to 2.8V the counting started again...
So I am guessing that the only purpose of the cells count is to know the voltage when to cut off.
Regards
