JCAustralia
01-25-2013, 07:39 AM
I am currently building a 20 inch twin mono and have a question about receiver connection.
I am using 2 Birdie receiver that both have BEC. I read on other forums that I should eliminate one of the BEC by cutting one of the BEC wire in order to prevent the receiver burning from over powering.
I will be using one of those Y-harness to connect the 2 BEC in parralel and then connect to the Receiver. If the 2 BEC are connected in parrallel then the voltage should not double, isn't it? Would that be ok for the receiver?:confused2::confused2::confused2:
Here are some pics of the twin mono hull I'm building.
Thanks.
Thanks.
