RCGasBoat
01-11-2013, 12:18 AM
I have a question. How does one maintain the scale look of a hull while allowing for heat extraction from the hull?
Example, if you build a Cintron Mystic, there isn't any NACA ducts on the deck except 2 side scoops and 3 small NACA ducts on the aft.
I don't think that would suffice to extract the heat generated even if you have water cooling. Drilling 6 holes turbine vents on the aft will take away the scale look of the hull.....
