View Full Version : F/S outrigger craftsman work )
MagnetO
01-10-2013, 04:36 AM
size is 90 cm , sponson booms together cutted from FC sheet , booms are allum , will be build for an order , takes 20 days for build all , no drilled , no hardware , no motors or no electronics , I will add turfin and bracket plus gift )
$250 plus shipping
only Paypal accepted
9157891579915809158191582
About hardwares , also I can add them , and I have HV swordfish ESC 8S 300A , new in bag and brand new , never used ,
but I will let you guys choose their own motors ,
I can include , brass tubing , flex shafts , rudder , strut , drivedog also , just ask me with this details ,
thanks
MEL
MagnetO
01-11-2013, 09:13 AM
all saw outrigger will be build with high quality epoxy and wood , all is handmade,
and plus
95mm rudder
3/16 strut
flexyshaft
brass tubing
brass tube teflon
drivedog
servo mount
motor mount with carbon bottom ( 40 size)
sponson boom tubes
sponson carbon legs
turnfin also will be handmade
everything ready to drive only without
Motor , ESC , servo , shaft collect for motor and prop. ,
and hatch will be designed FG (fiberglass) it will be less weight also
total will be $430 plus shipping , you will add your own motor and servo and transmitter , receiver
and you will fly on water
Namba328
01-12-2013, 04:41 AM
Is the length the total length with hardware or is it total length without hardware???
siberianhusky
01-12-2013, 06:39 AM
Neat ,clean build. Can you post a picture with batteries in the hull? Where does the CG work out?
I like the looks of that rigger! Very interesting!
MagnetO
01-14-2013, 11:23 AM
Hello mark , sorry for late answer , working day start really busy here , thanks for you kind words , try to do my best, there is nothing added on hull I mean main frame all wood , 1/8 and 1/16 plywood , sometimes I use laser cut , but this photo has handmade, there is not much actually difference , only lasercut takes less time , but handmade more fun and detailed also , all parts goes from my hands ) so I did this one little bit wider because of using HV batteries , and batteries can place easily front of motor , on the nose , there is enough place four 2 x 4s lipo and I fitted my own lipos easily to there , as you know outrigger has CG as possible as front of hull , but honestly this change with your setup ,it will change what motor and what lipos and esc placed in it , that's why I don't build RTR , everybody has their own setup , and everybody try to use what they likes ,
MagnetO
01-26-2013, 04:07 AM
thanks for you guys , I am buildin' 8th now , let me share photos ,
9260792608926099261092611
MagnetO
9261292613926149261592616
MagnetO
01-26-2013, 04:08 AM
9261792618926199262092621
MagnetO
01-26-2013, 04:09 AM
9262292623926249262592626
