View Full Version : Replacement Propeller strut for Proboat Mystic
Garrett
01-06-2013, 05:12 PM
My bushings are gone, and the strut is coming apart. Which replacement should I get? I was looking at these two: http://www.offshoreelectrics.com/proddetail.php?prod=oct-struts and http://www.offshoreelectrics.com/proddetail.php?prod=ose-80975
The OEM is Back ordered till February 2013. and I'd like to not be outta the water that long. any help is appreciated. Thanks
Heaving Earth
01-06-2013, 05:42 PM
How on earth does a strut come apart?
Heaving Earth
01-06-2013, 05:49 PM
Maybe post a wtb thread. Someone might have a spare. Honestly neither of those look great for your boat
MAMBA2200
01-07-2013, 07:37 AM
I put a speedmaster. 21 strut on mine just a few minor mods are needed its almost a direct replacement
Sent from my DROID RAZR using Tapatalk 2
Garrett
01-07-2013, 08:36 AM
Did you go with the round or flat strut? and was it the mono or hydro?
how much mod work did you do?
MAMBA2200
01-07-2013, 08:47 AM
i used the round mono as for the mods it was just making the mounting bracket fit think i had to spread it a little is all
Darin Jordan
01-07-2013, 10:19 AM
That's the route I'd take as well....
OR....
I put one of these on my Miss Geico that I ran at the 2012 Nats, and it worked really well...
http://www.ebay.com/itm/Adjustable-skeg-strut-3-16-prop-shaft-cable-electric-nitro-rc-boat-/140715172804?pt=US_Character_Radio_Control_Toys&hash=item20c34723c4
Cornering was amazing. I ended up trimming down the skag a bit to free up the boat for the setup I was running, but otherwise, the strut is a nice piece, and fits well... I did have to open up the forward end slightly to fit over the factory stuffing tube.
Garrett
01-07-2013, 12:10 PM
Thanks guys, I kinda like that skeg. Here's the problem that I've encountered, 91358 and here's the boat: 91359
Darin what do you mean open up the forward end? like with a drill bit or reamer?
Darin Jordan
01-07-2013, 12:14 PM
It looks like something must be out of balance or otherwise not spinning true. I've been running this hardware since the very first MG entered the country, and have never had one come apart like that. Check your driveline for trueness, and make sure the prop is balanced. I suspect you'll find that prop nut is adding to the problem.
I don't recall exactly what I had to do... it's been awhile, but I remember having to make a mod of some kind to get the stuffing tube to fit correctly. I believe I had to open up the forward end of the strut a tad (the cone piece). Sorry, I don't remember the exact details. I might have actually fitted the stock nose-cone piece to the new strut... Again, sorry, I just don't recall at the moment...
Garrett
01-07-2013, 01:42 PM
Darin, do you have a picture handy, that I can see what you're describing?
Darin Jordan
01-07-2013, 01:46 PM
Sorry, I don't... the boat is packed away and I don't think I put any pics of the new strut online...
MORIDE
01-08-2013, 08:08 PM
This looks pretty nice, but is the strut on backwards in the pics?
bob_t
01-09-2013, 12:07 AM
sure looks like it is backwards ... blunt end leading, sharp end trailing ... :confused1:
Or ... maybe they just drive it in "reverse" all the time :tongue:
Darin Jordan
01-09-2013, 12:49 AM
That's the one I have on my MG, and it's a nice quality piece. The skag is too long for the application. IT works very well, but you lose a lot of speed when you turn the rudder. I ground mine down to about 1/4" long. Otherwise, it is a truely nice piece for this application. You can open up the holes in your existing strut mounts so they can be slid outward slightly, and then this wider strut will fit between them.
You will likely have to modify the side of the leading end opening to fit the factory stuffing tube.
Go for it!
MORIDE
01-09-2013, 01:37 PM
These things are so much fun, I know how we all like to modify them, but what is the advantage of this over the stock setup?
Darin Jordan
01-09-2013, 02:23 PM
Much improved strut bushing... The stock strut bushings wear quickly and get pretty loose...
MORIDE
01-09-2013, 03:13 PM
Thanks Darin, I appreciate all your posts and insight about these boats, I have a Mystic and MG, I also have allot of RC products and I think these are the best stock performance products that I own. I know we all mod them as have I, but they are really great out of the box actually.
Darin Jordan
01-09-2013, 03:20 PM
You are welcome.
Just like the nylon bushings that used to come in the Traxxas Stampedes, and other "production compromises" that exist in almost any RTR RC vehicle, none of these are perfect. What I tried to do with these was get Pro Boat to focus on providing a solid base platform... the important, hard to change stuff, like hulls, motor layout, etc., and make everything else relatively simple to swap out for better quality stuff, once the stock parts wore, out. Seems to have worked thus far.
I like these boats as well... I think I'll have a BJ29 and a new IM31 V2 to run for this season... Looking forward to trying to continue the development!
Garrett
01-16-2013, 04:41 PM
I just installed that strut with the skeg on it, and with little modifcations to the piece it fits really well. now, I've just got to test it. thats the fun part. as far as modifications went, I had to grind the main strut because it was too wide to match the dual stock rudder assemblies that I made, and slide the engine back on the mounts to suck up the flex cable. other than that, it looks wicked. Dual Rudders, with a skeg on the Prop Strut. Thanks for the Help Everyone and Darin.
MAMBA2200
01-16-2013, 04:47 PM
got any pics of the finished product i would love to see it
Garrett
01-17-2013, 11:18 AM
92114921159211692117
Here's the pics guys, I'll have more soon.
St3alth_Frenzy
01-17-2013, 11:36 AM
how do you like the dual rudder setup? As im looking to do that to mine.
Garrett
01-17-2013, 05:03 PM
It handles really well, she turns on a dime. more so now than it did before.
Darin Jordan
01-17-2013, 05:06 PM
Looks interesting... Will be interested to hear how it works...
Just a little advice... the stuffing tube appears to be bent down below the level of the strut. You should really try to reshape it to get it to be a smoother bend to the strut. A pain, I know... this brass is pretty hard from China.
On my Elam, I had to do it by carefully covering the bottom of the hull with wet rags, etc... pulling the teflon and flexshaft out, and then "annealing" the metal so it would bend easier...
You definitely don't want it hanging down below the level of the strut if you can avoid it.
Garrett
01-17-2013, 05:08 PM
awesome, thanks for the tip.
Garrett
01-18-2013, 09:20 AM
Here ya go guys, I figured yall would be interested as to how she handles. it was a little windy lastnight, but it was the only free time I could grab.
Take 1 http://youtu.be/DADBXgZB4Vw
Take 2 http://youtu.be/4gn_vN1_u3g
