View Full Version : BBY PT SS45 build
RandyatBBY
12-28-2012, 04:57 PM
I have been building a set of hardware for the PT SS45 Sport Hydro. It will be running oval with 6S and SAW's on 8S. This is the start with a `1/4 flex shaft, Dual bearing strut.:smile:
http://img138.imageshack.us/img138/7264/0001st.jpg (http://imageshack.us/photo/my-images/138/0001st.jpg/)
http://img72.imageshack.us/img72/7734/0002xf.jpg (http://imageshack.us/photo/my-images/72/0002xf.jpg/)
Uploaded with ImageShack.us (http://imageshack.us)
Namba328
12-28-2012, 05:06 PM
why 1/4" flex? just curious.
RandyatBBY
12-28-2012, 05:58 PM
On 8S it will be rock solid no breakage.
LOVE6S
12-28-2012, 06:22 PM
Will a 1/4 flex rob a little power, compared to a 3/16?
RandyatBBY
12-28-2012, 07:11 PM
Not really, we have 4,500 watts that is 6HP, He could get by on 6S but when you run 8S that is a lot of power and it is just safer. We have been twisting 3/16 on 8S and were real careful on setup.
RandyatBBY
12-28-2012, 08:32 PM
Motor mount and runners done ready to set up Blind nuts and mount.
http://imageshack.us/a/img27/1300/0003ld.jpg
http://img812.imageshack.us/img812/6325/0004jt.jpg (http://imageshack.us/photo/my-images/812/0004jt.jpg/)
ray schrauwen
12-28-2012, 08:37 PM
Nice stuff Randy. Would this hardware suit a Whip Sport 40?
RandyatBBY
12-28-2012, 09:05 PM
I do not see why not it is adjustable from 5 inch rails to 4 inch rails.
RandyatBBY
12-28-2012, 09:39 PM
Motor installed with 10ton epoxy, Monday the stuffing tube.
http://img687.imageshack.us/img687/3017/0005wuc.jpg (http://imageshack.us/photo/my-images/687/0005wuc.jpg/)
Namba328
12-29-2012, 03:46 AM
is this for you randy or someone one else?
Looks good ! Make sure you stuff her full of floatation. A boat that big will fill up with water pretty good and go right down. I just had a nasty blowover on mine and destroyed the hull ripping the right sponson completly off but it still stayed above water for a while during its last retrieval. BLAHHH !!! No way she can be repaired this time. Good luck with your build !!
phil t
12-29-2012, 10:21 AM
Hi Randy, I will watch how you get this project together too, may want to do one for myself sometime. The 1/4 cable wont drag and is alot stronger than 3/16.
When you get ready to glue on the front canard be sure to cut out all the blue mark and the wing will fit in the slot, then square and level it up and mark the sponson side, cut that and use good epoxy to make a fillet.
Phil T
ray schrauwen
12-29-2012, 09:13 PM
I meant the rudder & strut actually, :tongue_smilie:
I would like to see a final wieght number on ths project. Mine comes in at 13.4 lbs which is a little heavy for my likeing so im hopeing to remove at least 1 pound from the replacement hull. Please post your wieght when you get there, thanks,
Gary.
RandyatBBY
12-31-2012, 04:17 PM
It is for a customer, Needing to pay my share of the bills in my family I have to do everything I can to make BBY profitable.
Phil T
Thanks for he info Phil all those little things help.
Gary, thanks I will keep all in mind.
Ray, I am using almost all standard stuff with a little mod on the strut arm to custom fit. It is not really a big deal I do it for all my boats. But yes it can work on any boat. if I know the strut adjustment like Phil puts it .(bottom of transom to top of table)
Brushless55
01-02-2013, 11:38 PM
Right on Randy!
I have this hull that needs finished...
we might run this class this year..
RandyatBBY
01-03-2013, 03:07 PM
Right on Randy!
Thanks, I have been hard at it fitted and built the stuffing tube one more solder to do the top oilier.
http://img72.imageshack.us/img72/8940/0006sum.jpg (http://imageshack.us/photo/my-images/72/0006sum.jpg/)
RandyatBBY
01-04-2013, 05:51 PM
Little more done, Installed Oilier and finished the seal of the stuffing tube.
http://img585.imageshack.us/img585/6900/0007cj.jpg (http://imageshack.us/photo/my-images/585/0007cj.jpg/)
RandyatBBY
01-05-2013, 05:42 PM
Spending a little time in the shop to catch up after the holidays. Installed the custom bracket on the boat. Servo mount next.
http://img202.imageshack.us/img202/2735/0008oqc.jpg (http://imageshack.us/photo/my-images/202/0008oqc.jpg/)
Shooter
01-05-2013, 08:19 PM
I like the rear motor mount. Simple, sound, and probably makes a good heat sink too.
RandyatBBY
01-05-2013, 08:28 PM
Always trying to be innovative. The tentative servo mount is a good place with the ESC, receiver pack and receiver on the right. Power cells in the front to make a great balance.
http://img819.imageshack.us/img819/2199/0009jz.jpg (http://imageshack.us/photo/my-images/819/0009jz.jpg/)
Shooter
01-06-2013, 09:50 PM
Nice. I really like the slot in the motor mount. I'm sure you are plenty aware, but I would ensure that long distance pushrod is in tension when in a turn. I run a pretty long one in my smaller PT and it seems to work well.
91332
RandyatBBY
01-07-2013, 02:39 PM
91332
One of the good things about a push rod on the left..... it pulls in the turn and not push when turning right. Gotta see id a 40.161 will fit.
RandyatBBY
01-08-2013, 02:03 PM
Turn fin completed and installed.
http://img248.imageshack.us/img248/5660/0010iu.jpg (http://imageshack.us/photo/my-images/248/0010iu.jpg/)
longballlumber
01-08-2013, 03:22 PM
Hey Randy,
You may want to look at putting a brace across the engine well area to help ‘tie’ the deck together at or near the sponson transom area. At the speed we are throwing these PT SS45’s into the turns the hull is doing a lot of flexing trying to keep the fin hooked up.
Later,
Mike
kevinpratt823
01-08-2013, 05:42 PM
Curious to see what is with the extra 2 tubes off the main stuffing tube......?
RandyatBBY
01-08-2013, 06:04 PM
Water cool stuffing tube to keep the epoxy from getting soft.
kevinpratt823
01-08-2013, 06:26 PM
Nice! So it's a large diameter tube creating a sort of water jacket around the actual stuffing tube, and the oiler tube passes all the way through the jacket and solders to the stuffing tube?
Sorry, still semi-new to building, picking up all the info I can.
RandyatBBY
01-08-2013, 06:52 PM
You got it! I do this on all 1/4 flex shafts and some High SAW 3/16 flex shaft with out Teflon liner.
RandyatBBY
01-08-2013, 07:20 PM
Canard wing installed two hours of cutting and fitting.
http://img826.imageshack.us/img826/5387/0012nj.jpg (http://imageshack.us/photo/my-images/826/0012nj.jpg/)
RandyatBBY
01-17-2013, 04:28 PM
http://img201.imageshack.us/img201/1102/0013pn.jpg (http://imageshack.us/photo/my-images/201/0013pn.jpg/)
http://img829.imageshack.us/img829/7645/0014mp.jpg (http://imageshack.us/photo/my-images/829/0014mp.jpg/)
ray schrauwen
01-17-2013, 05:17 PM
Very nice cowl Randy, spacious!!
If someone wanted a cowl like that is it alot of work? I'm still reading??
Oops. I was thinking it was a whip 40...
RandyatBBY
02-05-2013, 06:14 PM
I finished the paint and reassembled the boat.
http://img593.imageshack.us/img593/5531/0015lx.jpg (http://imageshack.us/photo/my-images/593/0015lx.jpg/)
phil t
02-05-2013, 11:00 PM
Ray that cowl is one of my optional turbine cowls It was modeled like the Unlimited hydro Miss 7-11 1985
phil t
02-05-2013, 11:01 PM
Like that color, looks like it is turning out nice.
RandyatBBY
02-06-2013, 05:33 PM
More pictures
http://img145.imageshack.us/img145/5554/0017hzq.jpg (http://imageshack.us/photo/my-images/145/0017hzq.jpg/)
http://img706.imageshack.us/img706/1589/0018xd.jpg (http://imageshack.us/photo/my-images/706/0018xd.jpg/)
RandyatBBY
02-08-2013, 08:36 PM
My part of the build is done, I hope the owner will add to the thread after he gets it. It was interesting building Phill's boat. There is a few things he does that I like a lot on the boat. The seam is real cool wel done Phill. It has inspired me to start a project I have been wanting to do build a 38/39 inch sport. A few years I will have it done.:wink:
Looks great!!.That color will be real easy to see aswell. My new replacement hull came in last week as well and its looking to be 2.5 lbs lighter than the last one that crahed and took off the right sponson.....so more speed!!!!! I can say the hard prt of my build was carving out the front to make room for the two 6s-5000 batteries. Did not like carving it up but these hulls need all the wieght as far forward as possible for SAW runs.
urbs00007
12-29-2013, 03:32 PM
gary, couple questions. how many cells are you running on 1530 . what is the status of the 1527 you had previously used in the boat? was it 5 mm shaft? I'm building own design saw hydro for 2014.
Brushless55
12-29-2013, 03:47 PM
Randy, any idea how a 1527 1D (2300kv) would run in this hull using 4s ?
thanks
FCM Racing
12-29-2013, 05:10 PM
Randy question on the paint any paint code and who makes the paint
Thanks
Gary
RandyatBBY
12-30-2013, 02:09 PM
thanks
It is a beast plenty of power on 4S I had mine in a Lift Master Rigger and it pulled a 48/50MM prop no problem.
Thanks
Gary
It was PPG's Omni Chrome Orange
FCM Racing
12-30-2013, 03:06 PM
Thanks Randy for the reply nice colour nice build
Gary
