View Full Version : Foam... hulls from scratch
ebfoxbat
04-04-2007, 05:33 PM
To the guys that have built the hulls from scratch:
I'm looking to cover some shaped foam in (carbon) fiberglass. I just don't know where to get the foam I want. Obviously I want the foam to be floaty. I'm just not sure if I should get special foam.
Any close-celled foam should work fine. Any suggestions of foam dealers?
avengersteve
04-04-2007, 05:52 PM
a long time ago i bought some from an apolstry shop to get the shape i wanted.
ebfoxbat
04-04-2007, 05:54 PM
Did it glass over well? and do you have any idea what kind of foam it was?
Stealth Assassin
04-04-2007, 05:55 PM
If you do not have the 4" blue foam block wall Insulation at your local home depot buy this stuff!
http://www.acp-composites.com/acp-sf.htm
ebfoxbat
04-04-2007, 06:19 PM
spyerfoam is only available up to 5.5" thick. That may not do it.
Rex R
04-04-2007, 06:26 PM
just took a look at 'dow's' website under BUOYANCY BILLETS you can get them 24" x 96" x 10" thick!(look for dock construction materials)
rex
Stealth Assassin
04-04-2007, 07:00 PM
Did you call them??? They told me differant! Also all you need to do If It was 5.5 Is laminate them toghther... BOOM thicker stock.
ebfoxbat
04-04-2007, 07:19 PM
I'm not thinking that 5.5 is enough. I'm going to look more into it. Thanks for pointing me in a good direction.
Rex R
04-05-2007, 04:25 AM
after doing a little poking around, I find that the 10" x 20" x 96" styrofoam runs about $100 usd shipping extra(and it will support 610 lb.s :)). 'lowes' might carry it.
ebfoxbat
04-05-2007, 05:22 AM
This is what I'm figureing:
$30 for the Spyder foam I need.
$30 for the resin and hardening agent
$45 for the 3yards of cabon fiber cloth I need.
That puts me at about $100 plus shipping. Which is good because that's what I planned on spending for a hull. Of course that gives me zero room for screwing up the shaping so I'll have to be meticulous. I wish I know something about hull design. :p
Darin Jordan
04-05-2007, 07:13 AM
I just use the pink Dow-Corning foam insulstion from Home Depot... Use Scotch 77 or a similiar spray adhesive to laminate blocks togther to get the desired thickness... Here's an example of how I used it:
http://www.rumrunnerracing.com/feforums/showthread.php?t=19946
Good Luck...
ebfoxbat
04-05-2007, 07:31 AM
Boy Darin, that's pretty. Nice work. I wish I knew even a little about shaping a hull or building a boat. Granted my project is for a surfer, we'll see.
Making it self-righting is going to be really hard I think. There's more too it than making the center-of-gravity far below the water line. I hope to use a second set of batteries as ballast for that. But then I'm looking at 24 cells or so. So 24 cells and 30 or so inch hull, how am I going to get that to go 15-20 mph?
Stealth Assassin
04-05-2007, 08:52 AM
Rex where did you find the 10" thick foam?
Rex R
04-05-2007, 12:21 PM
number of places, just use BUOYANCY BILLETS as the search terms for google
