View Full Version : Catamaran CG ?
chipgibbs
12-07-2012, 08:59 PM
On a Catamaran hull with the now typical overhang, how do you measure the CG? measure only the hull in the water or the entire hull including over hang?
Thanks
Chip
100 mph jet boat
12-07-2012, 09:34 PM
no overhang
like your cheetah would be 32in...... total boat is 34 1/8in
SirBudman32
12-07-2012, 09:41 PM
If thats the case I need to change my Cheetah
keithbradley
12-07-2012, 09:51 PM
Most use the splash chip, so measure from the sponson transom.
chipgibbs
12-07-2012, 09:56 PM
Thanks guys, This would explain why I keep blowin over. looks like I'm about an inch shy of right.
Chip
100 mph jet boat
12-07-2012, 10:11 PM
if i did it right :)
on a cheetah
hook a tape on the rear of the sponson riding surface and measure forward 9.6 in = 30% 10.24in = 32% 10.88in = 34%
SirBudman32
12-07-2012, 10:13 PM
Thanks, I try that
chipgibbs
12-07-2012, 10:14 PM
Well I trimmed the noodles and got the batteries to move forward a bit. Looks like I've got the CG at about 9' from the rear of the sponsons. Probably at about 28.5%.
I also originally built the boat using 4200mah batteries and now have 5000s. The longer battery can't be moved far enough forward w/o adding some more battery tray.
Hey...First build and I'm still tickled as s__t.
Chip
chipgibbs
12-08-2012, 12:24 PM
Gave the Cheetah a few runs this morning. Tried some different props and strut adjustments with the improved CG.
89856
89857
Chip
100 mph jet boat
12-08-2012, 02:50 PM
51 cool
what props??
how did it handle with the new COG setting??
chipgibbs
12-08-2012, 04:50 PM
The props I tested today were M545, M447/3 & X642. The best speed was the M447/3 @ 51mph. The boat seam good under full throttle but, anything less than that and it feels like it's plowing.
Not done yet
Chip
100 mph jet boat
12-08-2012, 06:13 PM
i think thats what tiqueman is trying to fix in this thread
http://forums.offshoreelectrics.com/showthread.php?38587-Fighercat-Cheetah-6s2p
chipgibbs
12-08-2012, 07:47 PM
yup, I've been watchin that thread too
