View Full Version : Electronics Problem?????????
MAMBA2200
12-02-2012, 05:32 PM
Ok guys i need help in a bad way i have 2 boats that are giving issues.I am running seaking speed controls in both boats one is a 120 and the other is a 180. When i first put them in the water and go to take off they blast out of the water and then seem to just go into safe mode. That is the best way i can describe it the seem to have full power for a split second and then only 3/4 power. I am using 2150 kv motors d wind and on my mystic i have blown 2 castle bec's in 2 runs. I have tried lowering timing making adjustments on my controler props and all i dont know what else to do please help.
Did you disable bec on the seakings?
MAMBA2200
12-02-2012, 05:38 PM
yes removed red wire
Jason4636
12-02-2012, 05:43 PM
And did you calibrate your throttle? Do you have the esc set to hard start? What do you have your lv cutout set at?
MAMBA2200
12-02-2012, 05:46 PM
Yes calibrated lvc i have changed also using 40c packs no hard start
Sent from my DROID RAZR using Tapatalk 2
MAMBA2200
12-02-2012, 05:59 PM
And also im not getting high amp spikes eagle tree says around 105-110 amps
SirBudman32
12-02-2012, 06:41 PM
turn the lvc off and time your run. I've dont the same with the T-180
srislash
12-02-2012, 09:38 PM
turn the lvc off and time your run. I've dont the same with the T-180Same with my 180 and my HV 80's.Had to turn the LVC "OFF".Then all was well. My 80's even went for a few runs before acting up.
ray schrauwen
12-02-2012, 10:11 PM
I just calibrate throttle and leave them on auto. Maybe a timing change but, thats it.
MAMBA2200
12-03-2012, 07:38 AM
I have done the timing change guess i will try the lvc and use a lvc alarm and do a short run and see what happens i guess what timing is best on a d wind motor???
SirBudman32
12-03-2012, 07:41 AM
I would start with 3.75 and go from there
The bec should have nothing to do with the esc troubles no? The bec just powers your radio I thought.... I dont use external bec so I'm not really sure about that. As far as timing goes, should be no more than 5 degreees.
Got any pics of the inside of your boat and setup?
Jason4636
12-03-2012, 08:59 AM
For d wind low timing, below 7.5. Y wind likes high timing, above 7.5
MAMBA2200
12-03-2012, 09:01 AM
thanks jason on the timing89507
rabosi
12-03-2012, 09:24 AM
The problem you described seems like the well documented Seaking LVC issue. You can try lowering the lvc in increments (eg 3.2, 3.0, 2.8...). Going to 2.8V worked in my case. If not you can try turning off completely as mentioned already. I've also noticed that better quality batteries seems to make a difference also (able to hold volts better under load).
How long has this been happening? What prop are you using? What is your strut depth? What is the cutoff set to? What batteries are you running?
I'm also curious as to why you aren't using a seperate pack for the bec? The seaking has built in bec, so why bother using the castle one if youre still powering bec with your packs?
MAMBA2200
12-03-2012, 09:48 AM
cause it drops my amp draw between 7-10 amps data by eagle tree
MAMBA2200
12-03-2012, 09:50 AM
the issue just started batts are 5000mah 40c shy lipo strut is dead level cuttoff is set to 3.4
Turn your cutoff down to 3. 3.4 is high for that esc. Ok I can see why you use the bec now... 7-10 amps is pretty small tho. Try raising the strut up an 1/8
MAMBA2200
12-03-2012, 11:43 AM
ok i will try to turn it down and then off thanks for all the help guys:buttrock:greatest forum on the web
