View Full Version : Please help with setup
MAMBA2200
11-30-2012, 01:32 PM
ok so i had the MC out for the second run yesterday and it did ok but i had raised the strut and its very slow on take-off but ran decent on top end only 35mph i have the strut about 1/8th up with 0 degree's of rise but this boat should be in the 40's running 3674 leopard 1900kv seaking 120a esc and 42x55 prop on 5000mah 40c packs any help would be appreciated:help:
100 mph jet boat
11-30-2012, 01:49 PM
did you program the esc??
my mc runs best with the strut level
MAMBA2200
11-30-2012, 02:09 PM
yeppers when it was level it would not get on plane
MAMBA2200
11-30-2012, 02:11 PM
here is the video
http://www.youtube.com/watch?v=KTw_f5eBogQ
lenny
11-30-2012, 03:38 PM
What is the timing set at on the esc ?
MAMBA2200
11-30-2012, 04:04 PM
im thinking 7.25
G-UNIT
11-30-2012, 04:33 PM
I have the same motor and was told to set the timing to the lowest setting as its a d wynd.
forgot what it is, 3 degrees ?
ps. I always like your vids.
MAMBA2200
11-30-2012, 04:37 PM
i will try the lower timing thanks for watching my vids :beerchug:
G-UNIT
11-30-2012, 04:42 PM
Yea nice fleet, what, you have a revolt, mc, mistic and a impulse, but no ul-1 whatsup. ha, ha.
MAMBA2200
11-30-2012, 05:01 PM
not much on the hydro boats cool to watch and yes that is the 3 boats i have really got my mystic hauling a$$ yesterday uploading a vid now but its short cause i blew a cap on my bec think it got wet for some reason i got allot of water coming from somewhere now:confused2:
100 mph jet boat
11-30-2012, 05:24 PM
what is you cog??
set timming at 3 - 3.5
most mc i have seen take a little bit to get on plane Not all of them but most of them.
MAMBA2200
11-30-2012, 05:27 PM
cog is about 30-35% i will try lowering the timing sunday
100 mph jet boat
11-30-2012, 05:36 PM
put your batterys as far back as poss.
Rocstar
I would lower the strut back down a bit. Sounds like the prop is running a bit shallow in the water. Make adjustments with your cog to get her flying level.
100 mph jet boat
11-30-2012, 05:39 PM
X2 I ment to say that aswell but hit post
Good call Roc
MAMBA2200
11-30-2012, 08:44 PM
Ok will do guys thanks for the input will let u know how it goes
Sent from my DROID RAZR using Tapatalk 2
Timing change will make almost no noticeable difference in speed FYI. Hope you aren't expecting it to
MAMBA2200
12-01-2012, 07:37 AM
No im not just trying to get help getting the speed with setup tips cause im struggling gtn the MC up to speed
Rnbuilder
12-07-2012, 11:52 PM
Try a M445 or a X642 I got a considerable speed increase over a 42x55. I also run a degree or 2 positive angle on the strut with the same motor esc combo.
MAMBA2200
12-08-2012, 08:52 AM
i have a m445 coming for it and a higher kv motor hope this will solve the issues im having
