View Full Version : flex cable
MAMBA2200
11-28-2012, 11:52 AM
just bought one of these for my son for christmas and wanted to get a upgraded flex shaft does anyone know who sells one that is ready to go for this boat im gonna run a 35a seaking on stock motor for now but i need the cable
SirBudman32
11-28-2012, 11:58 AM
Just unsolder the flex and get a piece of .047 Piano wire and put back in. did it to my daughters Mini.
MAMBA2200
11-28-2012, 12:14 PM
do you need a torch to solder it or can u use a solder gun
SirBudman32
11-28-2012, 12:19 PM
I used a torch but should be able to do with solder iron
MAMBA2200
11-28-2012, 12:21 PM
can u use one of those butane torches
SirBudman32
11-28-2012, 12:22 PM
Thats what I used.
MAMBA2200
and also can u use the same technique for soldering the flex cables?
MAMBA2200
11-28-2012, 12:24 PM
any special solder to use?
SirBudman32
11-28-2012, 12:26 PM
I just heated up the shaft till the flex came out and then heated up the wire and shaft and but them back together.
Jeff Wohlt
05-22-2013, 02:28 PM
I am working on a new 062 wire drive with new x432 prop and drive dog. I could mske new couplers but drilling out 47 to 62 is simple. Anyone interest? Getting a lot of emsils on this.
Sobie2
08-23-2013, 08:20 PM
Ok Jeff,
I just went to your site and ordered up your driveshaft setup. I had all the stuff from coupler to prop not for the octura 098 flexshaft but have been to busy to gut the boat (and I didn't want to). I already have my 3900 kv watercooled inrunner/outrunner (I don't remember its blue and from hobbyking) and a SeaKing 35a in place. All I had to do was enlarge the cowl opening to shoehorn in the motor, and then trim the motor mount to make the water cooling tube not kink. Up next is solder on a deans connector. Then install Jeff's 062 shaft. I have 3 octura props waiting Y531, X432, and X632. All in all its pretty plug and play should be good.
After this its some kind of 6s rig, Revolt 30 or Impulse 31 (or any other suggestion).
Sobie2
Sobie2
09-24-2013, 07:38 PM
I got my Jeff Wohlt 062 setup last week in the mail. I plan on installing it soon. I will let people know how it goes when finished.
Sobie2
AustinWolv
11-03-2013, 08:04 PM
Sobie, did you run it?
Sobie2
11-03-2013, 11:36 PM
No I haven't run it, the kit was not a quick plugin play as advertised. You had to drill out the driveshaft with a 1/8" drill bit and when I tried that the driveshaft spun out and the bit got stuck and 1/8 isn't big enough. So it's on hold till later. I even have a complete octura 098 shaft kit but heard this was an easy one... Nope :(
Sobie2
jrmagooo
12-26-2013, 06:57 PM
hi sobie 2. thinking of getting wohlt minimono kit also. saw your post and wondering if you made any progress. thanks jim
Sobie2
09-10-2014, 02:51 PM
It has been way to long, but I pulled out the old driveshaft, and enlarged the hole in the transom and front shaft support. I cut the 098 stuffing tube and teflon liner tube, and inserted the wohlt driveshaft (the one that I got appeared to be only an octura 098 assembled driveshaft cut to length and thus it wouldn't fit the existing stuffing tube. At any rate I have some epoxy and will epoxy it in tonight. The only thing I need to do is check the length the driveshaft needs to be sticking out of the stern before I set it in place. Then it is off to the water!
Sobie2
