BlackSnakeRacing
11-24-2012, 06:58 PM
So i will admit, the FE bug has bitten. I have been looking at forsale threads for a while and decided to clear milzee out of some gear. This is a list of what i got:
1x Delta Force 35" Pirate mono hull - New, polished
1x 34"(850mm)x20"(510mm) Carbon / Kevlar cloth
1x 12"(300mm)x4" (100mm)x 2mm Carbon sheet
1x Speedmaster 40 Rudder Assy. with 2 1/4" set back and dual water pick up blade and all hardware
1x 4-40 push rod, 1x Du-Bro HD 4-40 E/Z connector #490, 1x 2pk Joysway waterproof boots
1x Speedmaster 1.5"x1.5" Adjustable trim tabs, 2 pairs
1x Large turn fins -OSE 80066
1x Speedmaster 3/16(.187) Stinger drive assy.- SPDSD-2140
1x 12"(305mm) 9/32 K&S brass tube
1x 24"(610mm) Octura teflon tube to suit 3/16(.187) flex- oct187t-24
1x 24"(610mm) Hu**** 3/16(.187) flex shaft- b6664
1x Octura Coupler 5mm - 3/16(.187)
1x Octura 3/16 drive dog- oc6dm-3/8" o.d
1x Dasboata balanced, sharpened and cupped Octura X445 prop- New with some decals
1x Nylon lock nut, 1x brass bullet nut to suit 3/16 shaft
1x 5mm Thrust bearing
1x 20" 10mm Turnigy heat shrink, red and 20" of black
1x 4pk Great Planes large fuel line clamps
1x 33"(840mm) Large silicon water tube
2x Large OSE water outlets
1x Hatch lift nut, 13x OSE decals
1x PVC boat stand- used
Basically the whole setup except electronics and motor mount. I had a Castle 1717 1580 KV motor that i think will make this boat go pretty well. I needed a motor mount so i removed the mount from my osprey and made a mount out of 2mm carbon fiber the same as the basic mount.
http://i1201.photobucket.com/albums/bb356/tigercoastal/RCs%20i%20play%20with/Delta%20Force%20Pirate/CAM00142.jpg
http://i1201.photobucket.com/albums/bb356/tigercoastal/RCs%20i%20play%20with/Delta%20Force%20Pirate/CAM00143.jpg
First step i filled the top part of the hatch will epoxy to strengthen and level it a little to make covering it with carbon fiber a little easier.
http://i1201.photobucket.com/albums/bb356/tigercoastal/RCs%20i%20play%20with/Delta%20Force%20Pirate/CAM00145.jpg
Then i reenforced the whole hull with carbon/kevlar cloth, i did the hatch as well but am adding flotation at the moment so no pics yet.
http://i1201.photobucket.com/albums/bb356/tigercoastal/RCs%20i%20play%20with/Delta%20Force%20Pirate/CAM00144.jpg
Then it was time to start fitting the hardware. I dont think i have measured and re-measured something so many times in my life. I started with the hatch lift nut and water outlets
http://i1201.photobucket.com/albums/bb356/tigercoastal/RCs%20i%20play%20with/Delta%20Force%20Pirate/CAM00150.jpg
Then i started with the transom mounted hardware
http://i1201.photobucket.com/albums/bb356/tigercoastal/RCs%20i%20play%20with/Delta%20Force%20Pirate/CAM00149.jpg
