View Full Version : Swordfish 120A ESC on 5S?
bigwaveohs
11-21-2012, 02:37 PM
Wondering if it's a bad idea to run a Swordfish 120A ESC on 5S with an ARC 1850kV in a JAE 21?
MAMBA2200
11-21-2012, 02:54 PM
you should be fine on 5s thats gonna put you about 33-35,000 rpm i would just run for a minute and check temps and run another min and check again i run a 1900kv on a 120 seaking and it does good all dependent on your prop selection i use a m454 on that setup
bigwaveohs
11-21-2012, 04:07 PM
Thanks.
I was thinking about starting with a pitched H5 (45.1 x 80.8 x 114.3 mm) or my m445 (45.1 x 73.7 x 95.3
mm); third number is the added cup.
The stock X445 is about 45 x 63 mm, so my m445 is closest except for the cup.
Pete
MAMBA2200
11-21-2012, 08:27 PM
I meant to put m445 my bad
Sent from my DROID RAZR using Tapatalk 2
lenny
11-21-2012, 09:08 PM
I added 1000uf 35v caps to my 120a esc,
Helps keep thing cool.
bigwaveohs
11-21-2012, 09:22 PM
Yeah, I've got a 454 but it's in my other boat...
88920
MAMBA2200
11-21-2012, 09:29 PM
Very nice
