View Full Version : "Orange Cat" build 2013 - Fast and Reliable
cugino
11-21-2012, 07:24 AM
Hello,
for next season 2013 i am going to build my new boat. It is 930mm long custom build carbon/kevlar catamaran hull. I wasnt sure about the suitable hull lenght, beacuse my intention was fast setup, but i didnt want to ruin my wallet much :-) I Thing that under 1 meter long hull will be enough for good speed, reliable setup and low budget boat. We will see.
I am not boat racer. I only want fast boat for holiday bashing. I will build twin motor powered boat, just becasue i like the roostertail and handling of twins. Nothing more.
There is my custom made hull. It is carbon aramid hull. Bottom part of the hull is carbon/aramid, hatch and top part of the hull is aramid only. Resin is high strenght epoxy with aerospace certification. Hull is tempered, unfortunately not vacued. Next time i will be smarter.
88878 88877
I am not sure about HW i will use. I am only sure i will use wiredrive. It si simple, cheap, reacheble, reliable and efficient.
I am not sure, what motor, ESC (most likely T180) or battery i will use. I want to run only 6S configuration batteries, because all other boats i have i use 6S. I would love to try 6S A-Spec Nanotech 6600mAh 65-130C in 3S+3S configuration. Each pack in sponson. I prefer very light setup, all the build will be build within this phylosophy. All components will be as light as possible. Just try to look on 6600 Aspac nanotech - power/weight/capacity ratio.
cugino
11-21-2012, 07:52 AM
I like doing as much as i can myself. Buying thinks is realy simple, but with no satisfaction for me. And finaly i want to save as much money i can to have low budget boat. I have some time these days, so i can play :-)
Today I will prepare servo mount. I will use low profile china servo, because it is only one that fits this low hull quite well.
There is my servo mount: I like to prepare all my carbon part first. Then assembly part togather. I always build boats like that. I will start with smallest parts then assambling together. Finaly equip hull with prefabricated components.
8887988880888818888288883
cugino
11-21-2012, 12:55 PM
Hi folks,
Its time to move on. I ordered some HW. I think, it fits very well. Some modification were done outside the hull. Here are some pics.
8889588897888968889888899
I think, choosen HW is light and stiff enough for the hull this size and power. Stingers are shorter metric version (4mm). 4mm version offers me variable use of different props, either bored 3/16 or 4mm.
I prefer high revving setups, so everythink is done to handle high rpms well. But about driveline i will write more in future.
Next time, there is need to make some progress inside the hull.
cugino
11-23-2012, 08:37 AM
My build continues. Today i did some work inside hull. I started with receiver battery holder. I dont trust china BECs, either internal or external. I was considering NiMH batteries, mostly Eneloop. But i dont have good experience with NiMHs at all. But i have nothing to complain on A123 LiFe batteries. They are pretty suiteable for receiver. The voltage is very similar to 5cell NiMH, so there is no need for BEC at all.
8894388944889458894688947
cugino
11-25-2012, 02:35 AM
Today i could install stuffing tube. I picked up carbon tube 6/4mm. It perfectly fits in my stingers. With wiredrive it is perferct stuffing tube. I glued carbon tube leveled with bottom of hull then will bend to correct radius.
890398903789038
I also prepared some carbon and metal garbage. I made inlets and outlets from brass tube. I was warried about silicon tube sliding off, so i solder welt from copper wire. I think i will work perfectly.
8904089041
cugino
11-25-2012, 02:43 AM
Epoxy is drying, there is time to prepare some other suffs.
My servo links:
890448904289043
cugino
11-25-2012, 02:44 AM
Motor mount. It si made from 2x 1,5mm carbon sheets. Glued togather and then filed to proper shape. That was terrible and took lot of time.
89047890488904989050
mtbenjamin77
11-25-2012, 02:49 AM
Use a jigg saw with a tunsten carbide blade. cut slow works great takes about 10min
cugino
11-25-2012, 02:57 AM
Stuffing tubes already dried and today i need motor mount installation i already prepared. It was quite frustrating to align stuffing tube with motor mounts but i think that result is good enough. All carbon garbage is on it place. And my epoxy phase is done. There is nothing left to glue with epoxy. U can see, there is very few matterial added. I wanted very light build.
89051890528905389054
cugino
11-25-2012, 03:12 AM
Everythink is glued on its place, there is time to equip the hull with electrical devices and wiredrive assembly.
It is only my test setup:
Motor Turnigy XK3665 2100KV
ESC: T180
Props: I will start with X436 CNC alu prop, good enough for first testing.
Only i want is to trim wiredrive instalation and tune it to zero vibrations. After zero vibrations procedure is done, i will upgrade to better motors. I expect some suggestions of very experienced FE addicts :-)
89058890558906489063
cugino
11-25-2012, 09:02 AM
Wiredrive is 2mm wire with 4mm stainless propshaft. Wire is in teflon tube with ketron bearings on eaech end of tube protecting lubricant (silicon oil) to escape outside tube. Teflon tube is fully filled with silicon oil. I hope it will work. I expect little drag from amount of oil, but i hope, that libricant will last several drives, i wish whole day. After whole day i will remove whole wiredrive with teflon and fill it with fresh oil.
8906589066
There is prepared power combo waiting for installation. I am very curious how will they perform. Motor wires will be soldered directly to ESC PCB after installation inside the hull.
8906789068
cugino
11-25-2012, 09:47 AM
Ok, my build is almost done. Well, what do you think? :-)
Next step is paint. I will use 2K Glasurit or Standox car paint. Before that, i have to sand whole hull. I will send pictures after first paint iteration. Hull will be more white next time. :-)
liteumup69
11-25-2012, 09:51 AM
Looking good, keep the pics coming!
sampit
11-26-2012, 08:05 AM
Nice looking hull, with all the right bits fitted, nice and light it should be flying.
Any further info on the hull, how much does one cost, can another one be build to order? or is it just a one off!
cugino
11-27-2012, 02:16 AM
Thank you for your post. I hope it will be light enough to need less power, less capacity batteries a then less weight again.
The hull is only test modiffied protorype now, if it will perform well, there is little chance to do more hulls, but i dont know if any.
cugino
11-27-2012, 09:06 AM
Hi folks,
Can anyone give me rough amp draw estimation with following setup (test purposes only)?
Motor: Turnigy XK3665 2100KV
ESC: T180
Batt: 6S A-Spec NanoTech 6600mAh 65-130C
Prop: Alu CNC pro 36mm 1,4 pitch and Octura X442?
I think, it will be under 90Amp per motor with X436. But with X442 i have no clue? I am little warried about XK with X442.
If cat perfomes well, i will spend more money for better motors. Its to early, but what would you suggest. I was considering Tenshock EDF 2240/7, Lehner 1950/6 or NEU 1415 1Y. I am limited to 36mm dia. motors.
Or are there another good options?: MEGA, HET, Plettenberg, Kontronik, Hacker, etc..?
What do you think is the best choice and why? If everythink goes well, i will be looking for most efficient setup for speeds around 150kmh for SAW and 110kmh for bashing. 2x3S pack is only one possible battery configuration. So, my vision is to heve in the end two sets of prop. One set for bashing another for rare adrenalin SAW passes. :)
TheShaughnessy
11-27-2012, 07:30 PM
are you gonna spin the props in or out? Why 6s? thought those motors would be better on 4s. 46000 rpm is pretty high, even for a saw set up
cugino
12-03-2012, 04:05 AM
I decided to use 6S (3+3) because it is common configuration for my all other RC models. I dont want to have separate battery pack for each model, it is expensive.
I dont understand why is 46000 rpm high, when amp draw is low enough? What issues i can expect?
I have experience for five years with that high rpm setup using Hacker motors. Off course, perfect driveline and bearing is a must. It performs quite well and overall efficiency is satisfiing.
I gonna spin props in for few first tests, then out.
mtbenjamin77
12-03-2012, 08:07 AM
the motor will lose efficiency and create more heat than necessary at that rpm.
cugino
12-03-2012, 08:57 AM
Thank you for your reply,
do you have any data? or estimate of efficiency lost? Is there any graph of efficiency showing efficiency lost depending on RPM for any motor?
Thank you.
cugino
12-03-2012, 09:03 AM
If i understand correctly, u should use lower KV motor then i originaly intended. But with lower KV i should use much bigger prop to keep same speed. I thing, it is not acceptable, i love small props because of handling.
I think, i should find balance point for rpm/propsize/desired speeds/overall efficiency.
mtbenjamin77
12-03-2012, 10:24 AM
I would just aim for about 35000 to 37500 unloaded RPM. remember that is unloaded rpm. I've found in some cases a lower KV motor will spin higher loaded RPM than a higher KV motor in the same setup. The prop really needs to be determined by the hull design & size. Determine the best prop range for your hull and start at the smalledst size and work your way up. It's best to use some type of data logging to determine the current draw as your move up in prop size. You can also analyze your current draw by very closely monitoring your component temperatures. Also, it's been my experience that large CR props do really well on CAT hulls. Because they create more lift than samller props and the CR cancels the negative effects you would find in a single drive. To control your lift, first start with props rotating inward, then outward. determine which configuration worksf best and adjust your stingers to fine tune. Also setup your CG so that you have plenty off room to adjust your battery location to compensate for variable water conditions. The stingers can be adjusted for this but you lose forward thrust the more +/- angle you have on your driveline
cugino
03-13-2013, 09:50 AM
New season is going to come, my project is going to continue.
Package actualy arrived home. So here R some pics i must share with you all.
NEU 1415/1Y 2200KV will be installed.
9514795148
ray schrauwen
03-13-2013, 11:01 AM
Nice choice of motors. Your attention to driveline vibrations will allow you to get as much out of these motors as possible. Many don't realize how much power is lost to vibration as well as the damage to bearings and the heat created.
You are on track, this will be a very fast boat.
Your hull is absolutely beautiful ! Even Hanspeter would raise an eyebrow. Great work!!
cugino
03-13-2013, 04:24 PM
I willl do my best to eliminate vibrations as much as i can.
Now i am waitnig for my hull, it is at paintshop now. I am looking forward :)
Hull isnt build by my hands, maybe next time, i hope.
ray schrauwen
03-13-2013, 09:02 PM
Was it hard to remove the wires from the T180? How many watts is your solder iron?
cugino
03-14-2013, 11:47 AM
Removing wires was quite easy. I used 100watt high kapacity solder iron. Only about 0,8 second was enough to trasnfer heat to ESC connectors. Any part of ESC wasnt heated much. It is very safe to unsolder wires from ESCs PCB.
I prefer to solder motor directly to ESC to avoid high RPM motor-ESC sync. issues and low internal resistance of very short wires, wight comes to play either. Lighter is always better. Any saved gram is lot of saved watts.
cugino
04-15-2013, 10:05 AM
Hull is back from paintshop where 2K filler was applied. I already sended the hull again. Here R pictures.
Tomorrow i going to take her to painshop again, where next two coat of base paint will be there. I have already cut vinyl stickers, pretty simple, i like.
9718797188
iridebikes247
04-15-2013, 12:52 PM
Nice boat I imagine it will run best with props spinning in. Spinning out at high speed I usually run into problems but this is my personal exxperience.
cugino
04-15-2013, 03:50 PM
First test will be definetely with inwards rotating props. I am going to do first test with very conservative props 436 only to ensure, the driveline works perfectly and any other problems found last year were solved. Next step will be Alu CNC prop X442. I thing, it will be my final choice for this hull. May by ABC 1616 would work well. I am very curios now, i like high rpm setup.... :-)
Cooper
04-15-2013, 05:40 PM
Looks nice ! I too am a fan of small props and high rpm's. keep it going. Looks to be heading in the right direction and love the simplicity of the build. Those neu motors are going to be good to handle 45k + rpms.
focused
04-15-2013, 06:08 PM
What do you mean the hull is a prototype this is just a Freya MK II from Hydro&Marine , i have had the same hull in 2010 .
Freya MKII next to a Intruder S both from Hydro&Marine.
http://img442.imageshack.us/img442/4668/freya2.jpg
http://img441.imageshack.us/img441/2629/freya4.jpg
cugino
04-15-2013, 06:33 PM
Mine is little different, because of old 40Mhz system mine is custom made with aramid only hatch and top half of hull. Moddified bottom, because original sponsons wasnt symetrical and i wasnt happy with drive pad either, i cut hull and lowered little. There were few more mistakes that had to be corrected on low half of hull. Now i am very satisfied, but it took very much time, many hours to put hull to right shape. It is absolutely great hull, but not perfect as i need. But i have lot of time to trim hull to perfection. Maybe will be HaM intrested to improved next gen. Freya hull MKIII to be molded :-)
focused
04-15-2013, 06:43 PM
Ok, but you made it look like you createted a new hull by your self therefore i wanted to know.
One thing i dont get is you wanted a perfect hull modified to your wishes but you used inferieur china hardware , i have had the same rudder on a first china agitator clone and it bent beyond repair after one flip.
Bottom freya and intruder .
http://img801.imageshack.us/img801/4970/freya3.jpg
cugino
04-15-2013, 07:08 PM
Unfortunately i have no space to make my own hull from scratch. Only way how to make myself happy with good hull is to spend some time on closest to perfect one.
I picked this small one this time. I know about chinase HW it is weaker, but costs nothing. :) This project is about testing. Testing hull mods, ketron bearings, drive line,..., paint and so more. My personal little project. Goal was keep it cheap, but fast enough. If i will be happy with hull handling, i will go with better HW. But i like improving existing things. I like chinase HW as interemediate product. All my chinese HW already was or is going to be modiffied.
I am curious what was wrong with your rudder on agitator? Bended blade, arm, ...? What is weakest point?
31sonic
05-17-2013, 08:36 PM
hello I was wondering why you have those foam tubes in the front of boat. I am having trouble keeping the bow down.
31sonic
05-17-2013, 08:45 PM
99008
cugino
05-18-2013, 06:31 AM
Hi,
your colour scheme is absolutely beautyful.
Foam tubes in sponson keeps batteries in place. I only use velcro stripes to fix battery in its place and then force them down with foam tubes. I hope, it will protect against sinking when she crashes with major demage. This is just temporary solution.
Can you post photo of your build here? I would like to see your setup. Thank you.
31sonic
05-18-2013, 08:55 AM
Thank you for the information. Any info is greatly appreciated since I am new to the sport. 9902799028990299903099031
cugino
05-18-2013, 02:18 PM
Realy nice cat.
What batt do you use? And what KV and prop?
cugino
05-20-2013, 09:57 AM
She is finally back from paintshop, where several layers of base coat were applied. Tomorrow i am going to apply vinyls.
9915099151
cugino
05-21-2013, 01:28 PM
My simple layout:
99339993409934199342
Tomorrow clear coat will be apllied. After paint completely dries i am going to install power system.
cugino
05-29-2013, 05:02 PM
Hardware break in test runs. Few problems came into play, vibrations. Still with china motors and wrong props and still in white gelcoat.
Next week i will post video with new powerplant and paint on much bigger lake.
https://www.youtube.com/watch?v=GKz2v0Jvl84
ray schrauwen
05-29-2013, 05:21 PM
Is this a H&M hull or Chinese in the video? I wonder if those motors are Delta or Wye wind?? I have one here. Nice run for starting out. I like the Orange painted one, my Favorite colour.
cugino
05-30-2013, 03:30 AM
This is custom moddified H&M hull. I dont know if motors are Delta or Asterisk. I like Orange, it reminds me summer and it is very good visible on lake.
cugino
06-07-2013, 09:38 PM
Back from paintshop again with three layers of clearcoat:
100270100271
You can also notice set of NEU motors almost prepared to install. I thing they fits good. I was warried about bigger diameter of the cooling jacket. There is no much space left, i tried to install motors as low as possible.
cugino
06-14-2013, 07:05 AM
I soldered 22 joints, it took much more time then i originaly exptected. I hope, thet my new precise CNC 8 screw couplers will be good enough.
Few more photos:
100527100528100529100856
cugino
06-19-2013, 12:10 PM
Today i assembled boat, with hope of making first tests on my favorite lake. Unfortunately, i wasnt successful. I found out, that previous china motor failed and took one of the ESC to hell. I have to wait until hobbyking restock ESCs and then order one for installation.
One of the ESCs worked correctly and was able to ensure myself, that new configuration of wiredrive system works as intended. No vibrations at all, i am particulary happy. :-)
When i will receive new ESC, i am going to modify both ESCs adding new low ESR capacitor. I dont trust at all set of 4 capacitors added by manufacturer. Maybe, this modification is useless, because of oversizing of ESCs. I have seen these ESCs working in much bigger catamarans such as HPR 135 or Mystic 138. I expect amp draw below 100amp per motor continuous with peaks about 140amp per motor.
cugino
09-15-2013, 03:35 PM
Hello folks,
i finaly tested my cat. I took very long time, because one of the NEU motors was dead on arrival. One of the soft cables was terribly wrong soledered to wires of solenoids. I carefully resoldered and it seem it works quite well. I have to measure motor performance on bench to make sure.
I have to modify NEU motors, there are no axial distances on driveshaft and it makes backplate of motors to go off.
Here is video from my first test. It is short, just for bughunting of the boat.
http://www.youtube.com/watch?v=9zKo8D8rRKA&feature=youtu.be
cugino
09-16-2013, 03:59 AM
I have to modify my NEUs to work with my wiredrives.
All bearings on my 1415/1Y (2009) are probably glued on drive shaft. I have to make room for axial shift inside of motor. Well, i have to pull off all the bearings from the shaft.
Do you anyone know safe way to take of bearings? I would like to avoid demaging bearing or shaft aswell.
cugino
09-16-2013, 04:20 PM
I noticed on video, the rooster tail is very high. Is it ok? I thing the rooster tail should be more narrower, right?
grsboats
09-16-2013, 07:17 PM
Yes add some cup to the blades to lower the rootertail and gain some speed. boat looks great. Gill
cugino
09-17-2013, 03:29 AM
Thank you for reply,
is it possible to cup CNC alu props without breaking the tips?
grsboats
09-17-2013, 08:32 AM
I wouldn't do it with CNC props despite I have repaired some with extreme care.Gill
cugino
09-17-2013, 01:44 PM
I wouldnt do it either. U saved me props, thank you for reply.
Cooper
09-17-2013, 03:41 PM
I've cupped aluminum props with good success. I think the key is to carefully pound the shape. Any sharp edge in the bending process can result in a stressed area. Nothing extreme, and I did not anneal or treat before of after. If re shaping the whole blade, I would think a failure would be likely.
cugino
09-18-2013, 11:55 AM
Hello,
what type of bearing do you use. I used PbPTFE bearings that last only about 10 cycles. I have good experience with ball bearing, but they dont fit to my stingers.
I already doubled bearing on prop side, i hope it will extend life time. Will see.
grsboats
09-18-2013, 12:19 PM
Try to fit a pair of 3/16 lead teflon bushing to replace the ball bearings if possible .I have used this system for years and they last long.Gill
cugino
09-18-2013, 05:34 PM
I actualy use lead teflon (PbPTFE) bushing, that last only few cycles at my RPM. I dont know, what is RPM limit for LeadTeflon bushing. I use 2200KV on 6S, its about 48000 RPM, maybe to much for Lead Teflon.
I used to drive Ball bearing in my other mono setup with similar RPMs with no problems.
cugino
09-26-2013, 02:12 PM
I did some test this week. She drives well, but i found some issues i have to solve. One of the motor heats up more then the second one. Difference is quite big to accept it. One of the motor has 26 degrees Celsius and second one 35 degrees. It points on problem in cooling or motor itself.
What is your tipical temperature difference in your twin setups?
105739
jcald2000
09-27-2013, 07:36 AM
The inside motor on a turn is working harder so it runs hotter. If you were making a lot of say right hand turns the right side motor will be hotter. I keep my motors below 60 C or 140 F.
cugino
09-27-2013, 11:23 AM
Thank youf for your notice. I tried making turns equaly so ia can exclude this.
I am not affried of the temperatures now in general. It was quite cold when i was bashing. But i am affraid of hot summer days, where temperature difference can differ much more then now.
Run time was about 3 minutes. Telemetry (EagleTree V4) said, that peaks were about 220Amp for both motors, its about 110Amp per motor. Temperature 26 Celsius is very good result.
cugino
04-15-2014, 08:35 AM
Test day setup:
2X NEU 1415/1Y 2200KV, T180, 6S Nanotech 65-130C, Alu CNC X436.
114321114322
I will post video asap. She screams. :)
Fella1340
04-16-2014, 06:48 PM
The boat looks great and seems to go very well! Nice work. I don't understand the need to rework motors to work with the wire drive. Once the motor is loaded and running nothing should change to affect the wire drives. A few 0.001" endplay on the shaft is part of the motor design and changing that will chew bearings up fast once the motor is hot. I can't make any sense of modifying a motor to suit any type of drive. Can you help me understand what your talking about? Thanks
cugino
04-17-2014, 08:37 AM
Hello, thanky you,
i have two versions of NEU motors in the boat. One version is with free rotor axial shift, second one, rotor shaft is glued to bearings not allowing axial shift. On massive load axial bearings are pressed and there is need to compensate drive line temperature expansivity.
I have noticed, the bushing wears more quickly on motor with no axial shift.
cugino
06-10-2014, 06:52 PM
Todays telemetry data. Still same config
I am quite happy with Nanotech 65-130C 5000mAh.
116567116568
116949116950
cugino
09-20-2014, 02:59 PM
Hi,
here is my next video with one years old Nanotechs 65-130C. It runs pretty great, i think so.
Next try i am going to test with new props, X440 Tenshocks ALU CNC props.
I thing, Amp draw is quite low. Temperatures are below 40 degs. Celsius.
https://www.youtube.com/watch?v=iP9iVzpHR5w&feature=youtu.be
cugino
09-25-2014, 11:26 AM
I am not quite satisfied with speed of the boat. I think power units can do more. I would like to order new porps i found on promise hobby. http://www.ebay.com/itm/brass-538-left-right-prop-dia-38mm-pitch-57mm-P1-5-for-4mm-shaft-rc-boat-/140920070057?
Do you guys have any experience with these props? Are these CNC brass props? Do they fit my power units?
THX.
grsboats
09-25-2014, 05:32 PM
They don't look CNC and have 4mm shaft.With the same final picth I would stick with a better quality props like the Y537...you can use a KS brass tube for bushing if needed.Gill
cugino
10-09-2014, 04:33 PM
I have received props from link above and i have to say, they are bad quality. Absolutly not as hard as Octuras and badly drilled.
I would like to order new set of props. Do you guys have experience with this CNC brass props?
http://www.ebay.com/itm/VXP-CNC-Brass-Alloy-X442-2-42mm-1-4p-3-16-2-Blade-Propeller-Nitro-EP-Boat-Prop-/311006732651?pt=Radio_Control_Parts_Accessories&hash=item486972216b
kfxguy
10-09-2014, 04:44 PM
Contact dasboata. He can set you up with a nice set of twin props. Why chance something you know nothing about? Better to get something you know will work.......
cugino
10-10-2014, 07:27 AM
Thank you,
i will contact dasboata. I hope, he sends props to EU.
kfxguy
10-10-2014, 08:50 AM
Thank you,
I'm pretty sure he does.
dasboata
10-16-2014, 09:36 AM
thanks Travis I would do a pair of X442 and some ABC 1616/3 for him
