fla350tt
11-14-2012, 04:43 PM
This is kinda of a continuation from my first boat to see how different voltages effect motor and esc temps. And to see the speed difference in my boat hulls.
here is a link to the first boat: 22" rigger, leopard 2860 4050kv, 1- 7.4v 5000mah, etti 150 esc. boat only did 29mph with w/ x438.
http://forums.offshoreelectrics.com/showthread.php?30574-need-help-setting-up-an-outrigger-motor-prop
I transfered the running gear over to the delta force 22" vortex hydro and these are the numbers from the runs. boat ran well on first run so I have done no tunning and am very happy with the new hull. the only difference is two battery packs.
1st test
4050kv motor, 2 hyperion 7.4v 45c 5000mah batts parallel.
air temp 66
water temp 67
1:20 run time
33.9mph thats 4 over the rigger with no tuning. :)
batt temp 76
motor temp 80
esc temp 125
battery voltage at end of run 8.0 and used 2000mah
2nd test- just added a capp bank
a t 68
w t 67
r t 2:30 full throttle whole time
34.8mph
b t 85
m t 120
esc 140
batt v. 7.8 used 3000mah
3rd run- motr changed to leopard 2860 2190kv & batts in series 14.8v
a t 72
w t 68
r t 2:30 on and off the throttle, the pond is getting to short for this speed
37.8mph
b t forgot to check
m t 100
esc 120
batt v 7.9 used 2100mah
the boat was chattering across the water and was catching air when hitting cross wakes. I guess i need to add foam in the hull just in case. when I use the top speed finder on the OSE site it calculates a +3mph between motors, and that is what I got. my top speed is not what it claculates, I do not know the answer to this.
1st test
air temp 66
water temp 67
1:20 run time
batt temp 76
motor temp 80
esc temp 125
a t 68
w t 67
34.8mph
b t 85
m t 120
esc 140
a t 72
w t 68
37.8mph
b t forgot to check
m t 100
esc 120
