View Full Version : Swordfish data logging
worriedsick4u
11-12-2012, 08:46 PM
I have the new version 240HV and I can't get the data logging page to open when I click on it. Anyone else have this problem?
steveo
11-13-2012, 04:12 AM
the way i understand it its a raw file and i had to down load a program free it should explain it in maybe the help section and even bring u to a location to down load it, as i am not 100% my wife helped me, the esc is only supported by a few os systems and i did not have that type to run it so i think thats why i had trouble- shoot me a pm tomorrow and i will help u out, other than that its real easy to use, i have the 200 and have used to log my revolt30 with ul-1 motor
worriedsick4u
11-13-2012, 05:38 AM
Thanks Bro. I have the program downloaded. I use it to set up my ESC. I just can't get it to download the frigging data. I'll shoot you a pm later today. I think I'm gonna hit the local lake this weekend. Maybe we can meet up?
kevinpratt823
05-19-2013, 07:33 AM
I am in the same boat, running windows XP. Did you get this working?
I beleive I have my permissions settings open, but I'm no computer genius, and my hard drive only appears to have one location(C:), not sure where else to go as these are the 2 issues a search came up with.
I can change parameters, but can't open the data logging..........
worriedsick4u
05-19-2013, 08:23 AM
I gave up trying. If you figure it out, let me know.
kevinpratt823
05-19-2013, 09:20 AM
Will do, somebody out here must have figured it out..................???????
keithbradley
05-19-2013, 11:48 AM
Uninstall, re-download but do not save to drive C. Just save it to an arbitrary space, like "documents".
If it doesn't work, let me know.
kevinpratt823
05-19-2013, 04:51 PM
Tried this, still unable to access logging and records............
It still goes under C:documents and settings when I put it into "My Documents" not sure if that is what you meant......
It still goe under a seperate folder that acessed seperately from the C: (local drive) icon under My Computer.
keithbradley
05-19-2013, 05:08 PM
Kpratt is your ESC a 240 or 300?
Worriedsick, where did you get your 240HV?
I don't think Steve carries a 240 that datalogs...are you sure you have an ESC with a datalogger?
EDIT:
To clarify, the "Pro" Swordfish ESCs do not have dataloggers, only the "Pro+"
kevinpratt823
05-19-2013, 05:18 PM
Wow Keith, what a profound revelation, you are a genius. Mine is a 240pro hv, and on further inspection, data logging is not listed as a feature in the description on the OSE store.
I guess I was just under the impression that all the new versions had it.
I bought it as a quick replacement for the Castle 200hv that turned into a brownie last week, guess I didn't read closely enough.
Kind of a bummer that with all the new versions, this one didn't get data logging........
Edit: Mine is a 240hv Pro, apparently it is the Pro Plus that has the data logging.....
worriedsick4u
05-19-2013, 05:55 PM
Mine is the pro plus. So frustrating I quit trying.
keithbradley
05-19-2013, 06:14 PM
So yours has the gold label, correct?
When you attempt to upload the datalogs, you get a box that says "runtime error"?
Do as I mentioned earlier and re-download the program, installing it to another location. It will be simple and you will be reading data in just a few minutes.
Jason4636
05-20-2013, 07:35 AM
Keith is right, I kept getting the run time error. Uninstalled it, then reinstalled it in my documents. Everything works great
