kcpasco
11-09-2012, 04:30 PM
Hey guys I am getting rid of some stuff I have laying around that I am no longer using. Let me know if you have any questions about this stuff I will list as much info about it as I can.
Free Shipping on everything
88323
1. (Would like to sell them all together) $100 for all SOLD
18 metal props + 8 carbon props.
Carbon props:
45 mm 2 blade and there are 8 of them never used, fit 3/16th shaft
Metal Props:
4 35mm 2 blade off brand 3 for 4mm shaft and 1 drilled out for 3/16th shaft (these compare to the octura x435)
2 CL-08A 45 mm 2 blade off brand narrow blades, great for v-hulls 3/th shaft
2 37 mm 3 blade 3/16th shaft 1 of them has one bent blade can be bent back easily (these compare to octura y537 3 blades)
TFL 7450 2 blade 50 mm bent blades, can be bent back with a little work
Octura x435
2 Octura V937 3 blades one sharpened and balanced and one raw
Octura X440 3 blade raw
2 Octura V940 3 blade raw
Octura Y537 3 blade raw
Octura 2137 3 blade raw
Octura 1938 2 blade raw
88324
2. (Would like to sell these together) $75 for allSOLD
Brushless Motors:
2 3674 2075 KV motors with built on water jackets (1 has a blown front bearing that has been removed and the other is seized, these would be part motors)
3674 2770 KV motor with no water jacket (the motor turns with no resistance, not sure if its still good maybe a part motor)
3660 2726 KV motor with built on water jacket (Never ran brand new)
2 3660 2726 KV motors with black water jackets (Never ran brand new)
3660 2230 KV motor with purple water jacket (Ran quite a bit and its been awhile not sure how well it still runs)
8832588325
3.(would like to sell these together) $120 for all
Xpower UBEC New in the box
XPower 100 amp speed control (never used just missing connectors)
XPower 100 amp speed control USB program card
100 amp no name water cooled speed control (new in package)
200 amp air cooling fins no name speed control
8832688327
4. (would like to sell these together) $260 for both
Vintage Thunder 28inch vintage hydroplanes
- Miss Thriftway decals/rudder/strut/driveshaft/cablecollet/100 amp speed control/ 3674 2075 KV motor/ Watercooled motor mount/ Water jacket/ Turn Fin
-Plain White boat/ turn fin/ 35mm prop/strut/3660 2726 KV motor with built on water jacket/watercooled motor mount/collet
88323
Carbon props:
Metal Props:
Octura x435
88324
Brushless Motors:
8832588325
8832688327
