View Full Version : looking for more speed in my mystic.
Garrett
11-07-2012, 03:11 PM
I'm running 20C batteries and I talked to an RC Tech, he said if I go up with the "C" rating I'll get more Speed, but less Runtime, which Im cool with. With my 20C Batteries I'm able to get run times of 30 - 45 minutes, I also got rid of the deans connectors, and soldiered on 6.0mm Gold Bullet connectors onto the motor wires to the ESC, and from the ESC to the Batteries. also I upgraded the ESC to a HobbyWing 180A.
What Batteries would be a good combination for this ride?
11-07-2012, 03:59 PM
Forty-five minutes of run time? What capacity are your cells? How many Ps? With 5000 mAh capacity that's less than 7 amps average draw - you'd be moving ~10 mph tops....
MAMBA2200
11-07-2012, 04:15 PM
thats hard to believe :confused2:on 20c packs its even harder ive never got more than 7 or 8 min running very easy in fact im surprised those packs have not self destructed or not puffed :flashfire:i run at the lowest 40c and only get around 4-6min of hard driving do you have any video of these claimed run times
Garrett
11-07-2012, 04:33 PM
It'd be difficult to upload a long video.
My 11.1v 3cell batteries have a charge rate of 1C (5A), continuous discharge of 20C (100A), max burst rate of 40C (200A).
My 7.4v 2cell batteries have a charge rate of 1C, continuous discharge rate of 25C (125A), and a max burst of 40C.
I run 2 batteries in the boat in series.
Garrett
11-07-2012, 04:35 PM
48.5 mph is top speed with the 11.1's
MAMBA2200
11-07-2012, 04:47 PM
well thats great run times but i run mine in series just as most do but never got close to those run times with way higher c rating batteries
Garrett, running the boat for 10 seconds then letting it sit for 5 minutes then running again etc. doesn't count. There's just no way you run constant for more than 10 minutes. It's not even argue able. You should actually time your run sometime rather than just guess
Garrett
11-07-2012, 08:54 PM
dana, I usually run my boat when I can. so when I'm test running a boat for work, I try to take my mystic with me. the last time I did, I was running a 26 foot ProLine Center console Fishing boat with a Honda 200 four stroke, equipped with a 5 bladed propeller. the Pro Line was running a max speed of 32 mph. The Mystic was running at a max speed of30 mph. My Mystic with dual 7.4v LiPo batteries was not only able to keep up, but the test run lasted an hour, and we drove about 6 miles, and the Mystic was able to handle 4 miles The batteries started losing power at about 40 to 45 minutes. and (I dont run my mystic at full throttle all the time, I usually run at 3/4 throttle, because I like to have a little bit of wiggle room.) we also dont run the test boats at full throttle for very long either. I will say that it handles an 8 inch chop very well. and wake jumping not so well.
Garrett
11-07-2012, 08:56 PM
as I posted as the main topic. Does anyone know of more powerful batteries, looking to get more top end, not very concerned with the runtime.
Why do you need more powerful batteries if you're only using 1/4 throttle and hour runtimes?
How do you run at 30mph for an hour and only make it 6 miles?
You haven't posted what brand of batteries you use. How could anyone prescribe more powerful ones? More powerful than what?
Sorry bud, but nothing you say adds up
Garrett
11-07-2012, 09:19 PM
I said 3/4 throttle. and usually I'll have the boat go off in the distance, and come close, then go off again, and come close again. Ive ran it around other boats. over their wakes, and back to my boat.
Garrett
11-07-2012, 09:21 PM
Im using Venom-Group.com batteries.
Garrett
11-07-2012, 09:26 PM
which ones to you recommend?
Garrett
11-08-2012, 08:22 AM
awesome, thanks.
maxmekker
11-08-2012, 03:27 PM
mystic with hobbyking nano's. 45-90c and then 65-130c. There is a speed difference.I've been happy with my nanotech pack's good performance and good balancing.
http://www.youtube.com/watch?v=N55GDspMSXc&list=UURNlga8sE0qJBcPb_5FFovQ&index=20&feature=plpp_video
65-130c from 1,30 min
Another one.
http://www.youtube.com/watch?v=-w-e5QNmJCM&list=UURNlga8sE0qJBcPb_5FFovQ&index=17&feature=plpp_video
Garrett
11-10-2012, 02:29 PM
Maxmekker, what mAh are you running?
Garrett
11-10-2012, 02:31 PM
CX or EX batteries?
maxmekker
11-10-2012, 04:20 PM
I run HK nano's. 2x2s 4400 and 5000 45-90 + 65-130c packs. Not the biggest, but I got a few packs ,and if I manage to get 3-4 runs I'm happy that day :-) winter time here now( no snow yeat but dark and cold) so maybe next year I'll try some 4s in parallel.
Garrett
11-19-2012, 02:15 PM
I'm Running 5000 mAh batteries
