View Full Version : Anyone solder like a pro?
Azmarine
11-06-2012, 10:30 PM
Anyone on here solder like a pro? I've got the proteus motors and I would like to run them in the triangle configuration, but I don't have a soldering kit that can handle that kind of soldering. I don't want to buy something ill only use a couple times. Let me know please.
egneg
11-07-2012, 08:53 AM
I thought they came with the jumpers?
carlcisneros
11-07-2012, 09:41 AM
they come with the wiring (if memory serves) to construct the jumpers.
I could be wrong ya know,,,,,,,,,,,,
You are correct Carl, they come with the parts, but need to be assembled.
egneg
11-07-2012, 10:12 AM
I can do it for you, just need the parts and CL measurements of the motor connections - lmk.
Azmarine
11-07-2012, 03:27 PM
How much? I have all the parts
egneg
11-08-2012, 08:28 AM
Just pay postage both ways.
runzwithsizorz
11-08-2012, 11:04 AM
What a guy! Hey Chuck, I've got a mini torch, and a couple of soldering irons, but neither seem to get hot enough. One even *claims* to have a 140watt turbo booster. What iron do you use, or would recommend?
egneg
11-08-2012, 11:21 AM
I use a 230 watt gun for bullet connectors.
Azmarine
11-08-2012, 09:40 PM
Just pm me the address, I appreciate it
egneg
11-09-2012, 08:24 AM
PM sent.
crrcboatz
11-09-2012, 03:48 PM
Can u give me a link to this soldering gun? How pricey is it?
egneg
11-10-2012, 07:57 AM
I got it at Radio Shack ...
http://www.radioshack.com/product/index.jsp?productId=2062752
steveo
11-11-2012, 04:19 AM
if u want a reliable soldering unit radioshack has this tool i have used for years, i think i have had afew of them i take it everywhere i go with my tools i have soldered hundreds of connectors big and small and i use the torch head to solder my flex shafts to the stub shaft. portable light weight and no cord
http://www.radioshack.com/product/index.jsp?productId=2062753
Azmarine
11-16-2012, 03:26 PM
Here are the measurements
TurboZ
11-16-2012, 11:40 PM
Wow Egneg, can I ask the same of you for a Aquastar? I'd be happy to send a few bucks in the box for your time. :) Here are the specs for the AS:http://www.hobbyking.com/hobbyking/store/__24853__Turnigy_AquaStar_T20_3T_730KV_1280KV_Wate r_Cooled_Brushless_Motor.html I'm pathetic at soldering and would love to know it was done correctly. Cheers.
egneg
11-17-2012, 08:14 PM
First configuration is done.
88706
TurboZ
11-17-2012, 09:03 PM
Awesome!!!!!
Azmarine
11-17-2012, 10:59 PM
Looks like top notch work.
egneg
11-18-2012, 06:27 PM
This is where I am right now.
88722
TurboZ
11-24-2012, 04:48 PM
890198902089021 Not sure if the PM photos made it, but here they are just in case. Thank you for your help and let me know if you need more specific measurements.
egneg
11-24-2012, 05:35 PM
Those will do just fine - thanks.
gyrotron
02-09-2013, 10:27 AM
Hello Egneg.
Do you still have the wood block with the template to do this solder? I have a proteus motor too that needs the same connections. I tried making this solder for my first 42" build but I did a slopy job :doh:. I'll be glad to pay for a well done solder on my motor's connection and be able to rule out a bad motor connection on my build. Could you do this work for me? What would you need me to send you besides the parts that came with the motor?
Thank you :help:
egneg
02-09-2013, 12:10 PM
Yes, I still have it. Besides the parts all I need is what configuration you would like as from my experience there are only enough parts to do one or the other. I will send a PM with address and paypal info.
egneg
02-14-2013, 02:59 PM
You sent enough bullets to do the ESC side on one of the configurations - may I suggest the one on the right - just let me know if you want male or female.
gyrotron
02-14-2013, 03:42 PM
I think we would want males on all of them because we'll have females on the actual ESC correct? Is that what you were thinking? Let me know what is your suggestion.
dasboata
02-14-2013, 03:55 PM
Nice job ! the connectors are made to hold 2 # 10 wires ? (Gas Guy lol)
egneg
02-14-2013, 05:21 PM
Yes, that would be my choice.
egneg
02-14-2013, 05:22 PM
Thanks, yes - these are 8mm connectors so you can fit 2 10 awg wires.
