View Full Version : 1" belt sander $35 coupon Harbor Frieght
kevinpratt823
11-06-2012, 06:56 AM
I already have this, and it is great, especially for rough work on props. It comes with an 80 grit belt, way too rough, I ordered 1"x30" belts on ebay.
Like I said, I already own it so go ahead and print this coupon.....
http://widgets.harborfreight.com/wswidgets/common/displayCoupon.do?week=more_coupons&campaign=wkend111212_dynamic&page=coupon8.html&cust=02009082056&keycode=1004&single=true
ray schrauwen
11-06-2012, 08:23 AM
I'd like to find one of those for that price in Canada.
egneg
11-06-2012, 10:18 AM
I use the 120 grit.
kevinpratt823
11-07-2012, 01:58 PM
I use the 120 grit.I got a pack of 120's along with the sander at Harbor frieght, but I found if I'm not careful, it'lll take off more thane I wanted from the wrong areas(tips). I also thought about cutting the belts down to make them narrower and easier to get in on at various angles.
ray schrauwen
11-07-2012, 02:25 PM
I find Octura's 642 & 645 to be very thin at the tips and it's very easy to take off too much. The X4 series is not as bad and Grim props are of course harder and work well with a belt sander.
kevinpratt823
11-08-2012, 06:37 AM
Really?, the grim props seem softer, just much thicker, to me when I put a file to them.
egneg
11-08-2012, 08:15 AM
I use the part of the belt above the steel plate so it forms to the shape of the blade better.
Doug Smock
11-08-2012, 11:45 AM
Yep, or remove two screws and the plate comes off.:thumbup1:
kevinpratt823
11-08-2012, 02:01 PM
Looking to hook up a vacuum to the port on the side, what are you guys doing to control the hazardous Beryllium dust?
egneg
11-08-2012, 02:02 PM
Same thing ... I have a shop vac hooked up.
