View Full Version : Adhesive for Lexan?
tlandauer
11-04-2012, 06:31 PM
What is the best to glue Lexan?
I am making a sub hatch for my Mean Machine, the .050 11x14 Lexan needs to be extended , what type of adhesive? Epoxy, CA?
Any ideas? :confused2:
Thanks!
I used the two part epoxy that comes in the plunger. The one that is made for plastics. It smells really strong so use in well ventilated area.
tlandauer
11-04-2012, 06:34 PM
Thanks Dana!
11-04-2012, 10:27 PM
A MUCH better adhesive for Lexan is E6000 by ShoeGoo. This is an industrial strength adhesive with remains flexible. The problem with using epoxy is when the Lexan flexes - and it does - the epoxy will crack or un-stick. Not so the E6000. It is found in hobby and craft stores, and of course on-line.
http://www.eclecticproducts.com/_media/062106_e6_E.pdf
Chilli
11-04-2012, 11:06 PM
I like Goop which I guess is similar to ShoeGoo. I find it's also one of the best things for attaching pool noodle.
tlandauer
11-05-2012, 03:02 AM
Wow, Thanks Fluid! I was hoping to find something that will give me some flexibity.
tlandauer
11-05-2012, 03:03 AM
Thanks Chili, now I know what to use for pool noodles!
crombyzombie
11-09-2012, 09:50 PM
IPS weld-on #16. I work with it and its really strong. Cures Fast but be careful its a little thin. Dont squeeze the tube or you'll glue everyhing on your bench together.
Mark
tlandauer
11-10-2012, 02:14 AM
Mark
Thanks, I learn something everyday! :banana:
