View Full Version : how do u set up a rc mono with a stinger
jamie
11-04-2012, 12:26 AM
hey guys
i am new to FE monos and i am wondering if this set up down bellow is ok eg placement
878558785687857
jamie
battery placement
jamie
11-04-2012, 02:37 AM
bump
siberianhusky
11-04-2012, 05:24 AM
CG should be 27-30% of the total length for a typical mono, measured from the transom. Static float tests don't tell you much about component location.
I'm not a big fan of stinger setups, a properly set up strut gives you much more adjustability. ONce a stinger is mounted you are stuck at that depth for better or worse. Every boat I've built has benifited from being able to adjust the height of the prop. SOmetimes it takes a very small adjustment to go from a poor running boat to one that rips. Especially if you like to mess around with different props.
jamie
11-04-2012, 04:24 PM
this boat here is just a play boat iam build people are giving me alot of stuff to do it and one of the parts i got given was a stinger
BHChieftain
11-04-2012, 09:47 PM
I have a nice stinger setup on my Toysport Triton. With it I was able to ditch the trim tabs.
http://forums.offshoreelectrics.com/showthread.php?29889-Lazy-man-s-driveline-rebuild-(converting-metric-to-standard)
Chief
siberianhusky
11-05-2012, 05:54 AM
Then your strut wasn't set up right!
jamie
11-05-2012, 04:09 PM
i havent got trim tabs or turn fins yet
borgie
02-10-2013, 05:55 AM
this is the finished product guy enjoy http://www.youtube.com/watch?v=ytKIxwPVG_Y&feature=youtu.be
lenny
02-10-2013, 08:39 AM
Nice to see you got it together and running,:tiphat:
What size prop is on it and what motor is that and kv of it ?
It does not sound or look like it is getting on plane for you.
Can you take a couple more pictures of the setup with the cells in place and of the transom hardware,
Just trying to see where it is set at,
And help you with adjustments to make it run a lot better for you.
Also with the adjustments you may gain longer run times to for it.
It could be the CG or stinger need to be adjusted some or the prop to.
Ttyl.:beerchug:
lenny
02-10-2013, 10:14 AM
Thanks Egneg I did not see the setup at first,:tiphat:
And that the motor was 1620kv on 3s.
So setup is 120a esc motor fsd 3660 1620kv prop x637 ( on 3s. ? :huh: )
Yep, That would stop it from getting on plane.
borgie
02-10-2013, 04:43 PM
could you help me with my set up prop, angle of stinger,ect
borgie
02-10-2013, 04:48 PM
here are some pics of the rear it does run turn fins as you can see in one of the pics
93539
93540
egneg
02-10-2013, 04:55 PM
Start with the stinger neutral ... parallel with the bottom. See how it runs - to wet raise the stinger - front bounces drop the stinger. Also a larger prop at that KV will help ... say a Prather 220.
lenny
02-10-2013, 04:56 PM
Hi,
Yes I will try to help.
What batteries where you using in the video ?
Like egneg said to do,
And after you adjust the stinger and trim tabs and turn fins to neutral,
Just adjust the stinger up and down for testing the first time and see how it rides in the water.
Test it out, At 3/4 throttle to full throttle to see if it gets up on plane.
But run it in a straight line left about 75 foot and then to right to see how it's riding and laying on the water.
Later we will work on,
Making turn good.
It will be easier after it rides good on plane.
borgie
02-11-2013, 12:37 AM
i was gonna run a x442 will that make it get up on plane
Richie the shipwright
02-11-2013, 01:13 AM
Hey borgie, good to see you made it to the water mate. Bonython park eh? I used to rip that pond up with a few f.e. monos and riggers years ago, back when nicads were new technology.....
Lenny and egneg's advice is spot on. If youre still not sure about your setup, try and get to mawson lakes next weekend. Doc and i will help you sort it all out. Docs boat is worth seeing too!! :-)
borgie
02-11-2013, 01:17 AM
what time and do you have face book it will be easier to msg u
borgie
02-11-2013, 01:18 AM
yes Bonython park
lenny
02-11-2013, 01:25 AM
Hey,:tiphat:
That would be great for him and his boat to,:tongue_smilie:
So did you guys paint the big bullseye on the wall for Doc yet ?:lol:
Rick what S cells are you using first ?
02-11-2013, 01:30 AM
Usually between 10 and 12 oclock. Ill get back to you when i know for sure. Sorry dont have facebook... Ill pm you my phone number later.
02-11-2013, 01:41 AM
Lenny, Decided he doesnt need a bullseye... hes in love with that damn wall! I swear he's gonna make it THROUGH the flaming thing sooner or later... :-)
lenny
02-11-2013, 01:52 AM
Maybe some horse blinders would help.:rofl:
You know what they say, Love a first sight. :hug1:
drwayne
02-11-2013, 02:18 AM
How in heck did Jamie's thread degenerate to the Richie&Lenny half arsed comedy show ?
haha
Dont answer that, it's a rhetorical question.
I dont need a bullseye.. there is so much width it's hard to miss ( the true talent is avoiding it, not the impact ! )
Namba328
02-11-2013, 02:28 AM
hey guys
878558785687857
a answer to ure question (how do u set up a rc mono with a stinger).....
Very Carefully XD.
borgie
02-11-2013, 02:33 AM
thanks for you're very interesting answer lol
egneg
02-11-2013, 07:41 AM
I think a X442 will show some improvement.
Southwest
02-11-2013, 08:59 AM
How do you make adjustments of turn fins to neutral?????
lenny
02-11-2013, 09:34 AM
One step at a time,:tiphat:
Put them up and out of the way.
And just take them out of the equation for now.
Hey Doc,:tongue_smilie:
We were just thinking of you.:lol:
Maybe some wings to fly over the wall and a 3ch parachute.:popcorn2:
borgie
02-11-2013, 05:42 PM
Will a x442 be ok with a 3s battery?
02-11-2013, 06:05 PM
Yep should be fine. Ive got a box full of props we can try on the weekend, patience is a really big part of this hobby too!! :-) Remember what i said about ken warby?..... He didnt go out and run 400mph on his first try. Sometimes you have to slow down to go faster....
borgie
02-11-2013, 08:05 PM
And is it Sunday because Iam busy saturdays, btw on this boat it only has 27mhz (all my other have 2.4ghz) I also might not have enough batt life because it is 3s@2600mah
