View Full Version : Mystic maiden run
MAMBA2200
11-02-2012, 10:43 AM
well took it out to try it out and i must say i really like this boat handles good seems fast i had 30mph winds yesterday so i was just feeling the boat out mostly didnt get to crazy with it i had already flipped my revolt earlier her is a vid i made driving and filming at same time you can hear that wind blowing set up is seaking 120 tacon 3674 1900kv 2 pole motor with a m445 prop and 4s still got low 40's and could not open it up
http://www.youtube.com/watch?v=XVkJU8s1Th0
MAMBA2200
11-07-2012, 12:28 PM
im getting allot of lift on this boat on glass water i have the strut down even with the bottom of the boat and the hop starts do i need to lower the strut more or move the batteries forward more
100 mph jet boat
11-07-2012, 04:44 PM
i would try moving the batterys
MAMBA2200
11-07-2012, 04:49 PM
ok will try that first i had to fix the trays the other day they both came loose so i re epoxied them down and completely covered them in velcro for just that reason tomorrow is my day off if the weather is good gonna go run it some thanks jet boat
Raise the strut up. It's too low
MAMBA2200
11-07-2012, 05:17 PM
raise it up will that not lift it more :confused2:
No. Your prop is too deep. Just try it, raise it so the bottom of the strut is about 3/16 above sponson bottoms. You'll see the difference
MAMBA2200
11-07-2012, 07:52 PM
OK thanks again dana
Sent from my DROID RAZR using Tapatalk 2
Yw let me know how it works for ya
MAMBA2200
11-07-2012, 08:17 PM
You know i will my friend thanks for all your help
MAMBA2200
11-09-2012, 08:33 AM
well dana it didnt work well for me i flipped my boat twice in less than 10 min i moved the strut a little at a time and never could get it to stay down i did get one good pass got 52mph but she was about to flip then also i just got off the trigger b4 it did and i played with the battery placement also to no resolve i dont know what to do now got any more ideas:confused2:
100 mph jet boat
11-09-2012, 08:41 AM
im still new to the rc boat world and not shur if this is a problem with rc boats
but i would check the bottom to see if it has a hook in it
when you raised the strut did you keep it level or did it give it some poss. angle???
MAMBA2200
11-09-2012, 08:44 AM
well if it had a hook it would pull the nose down :noidea:
How far were you able to get the strut above the sponsons?
100 mph jet boat
11-09-2012, 08:58 AM
dose it just ride bow high or it porpoising
nose comes up hook set's it back down and the air picks it back up even higher then it drops then even higher tell blow over
MAMBA2200
11-09-2012, 09:24 AM
a good bit
its bounces for first 30ft and then settles and then just lifts till its over
100 mph jet boat
11-09-2012, 09:43 AM
whats a good bit?? 3/16, 1/4, 5/16
is it level, pos. or neg angle??
what is your COG set at ?
im shur Dana and others would know better, I just trying to learn something here
MAMBA2200
11-09-2012, 09:52 AM
i had it up a good 1/4 cog is about 30%
MAMBA2200
11-09-2012, 09:55 AM
here is the video of the first run
http://www.youtube.com/watch?v=hYl3z1hPxcw
100 mph jet boat
11-09-2012, 11:03 AM
what is the strut angle?
also just for sh and giggles put a straight edge on the bottom and see if you have a rocker or hooked bottom
MAMBA2200
11-09-2012, 11:33 AM
no hook angle is up not sure a perfect degree but its angled up should i raise it and level the strut by bending the stuffing tube:confused2:
100 mph jet boat
11-09-2012, 02:44 PM
raise it to 3/16 and make it level with the bottom of the sponsons, yes sometimes it's necessary to bend the stuffing tube just go easy
raise or lower the strut will raise or lower the stern of the boat, angle the prop up or down will raise the bow up or down
so if the prop is angled up it will pick the bow up
MAMBA2200
11-09-2012, 02:59 PM
3/16 above the sponsons
100 mph jet boat
11-09-2012, 03:32 PM
i fixed it
I set the boat flat on a table then roll a drill bit under the strut
note all settings and what changes it made and do 1 change at a time
it takes time to get it right so dont get upset with it, as to me doing set up stuff and checking speed and handling is the most fun
MAMBA2200
11-09-2012, 03:35 PM
ok thanks for the help
100 mph jet boat
11-09-2012, 05:42 PM
think of it as you would for them Sweet STV's
