View Full Version : Revolt 30 speed
Revolt30
11-01-2012, 03:07 PM
Tryed the M545 Prop top speed is 41.1Mph.How are you guys getting in the high 40's???sterring tabs set high as they will go batteries at the back of tray!! Any ideas how I can get more speed.With a prather 225 was going 40.8mph without sterring tabs up!
Mike Caruso
11-01-2012, 08:33 PM
That M545 prop needs a lot of work as it comes. I am working on one right now. The Grim 68 mm on my RV ran 45 on choppy water only runs 40.6 on glass water. The Grim prop needed lots of work also.
Revolt30
11-02-2012, 10:14 AM
Thanks for reply.What are you doing to the Prop and what type of balancer are you using?
longballlumber
11-02-2012, 10:25 AM
Revolt30 - It really sounds like you need to make a strut adjustment to loosen the boat up.
later,
Mike
giobors
11-07-2012, 01:54 PM
Hi Revolt i was the first to use the m545 more here i gave some little suggest in this thread, hope this can help you, Giorgio thttp://forums.offshoreelectrics.com/showthread.php?37597-Stock-Revolt-hit-46-7mph-75-2kmh
