View Full Version : Water lines done what do you think good or bad
justski
10-15-2012, 10:21 PM
water lines are all aluminum tubing very little Silicone Tubing ....i made the tubing holders from left over material from the World War II,Waco CG-4A gliders that were built at the Ford Motor Company Plant in neighboring Kingsford MI that my dad had in the garage from my grandpa....i made them so i could put the tubing in with rubber grommets to maybe help with any vibration i hope..lol...i ground them i lil bit on the bottom so the expoxy will hold better ill in stall them to night and take more pictures
86351863528690786908
SweetAccord
10-15-2012, 10:23 PM
Nothing wrong with it! Just be sure the silicone lines are a tight fit so they don't pop off under pressure. They look tight.
RaceMechaniX
10-15-2012, 10:51 PM
Should be fine but I would add zip ties to make sure the water lines don't come off.
KartRacer
10-15-2012, 10:53 PM
water lines are all aluminum tubing very little Silicone Tubing is this good or bad ...i will be mounting the tuning i just dont have anything good yet i want to make something they will snap in to like spark plug wire holders
8635186352
I use the clips on the water lines ,available here at Steve,s , very inexpensive!
Make-a-Wake
10-15-2012, 10:58 PM
Looks very nice, i have gone to aluminum tubing on the long straight sections. I certainly decreases "friction", increases flow, and is just more efficient overall. Plus it looks very nice................bling bling!!
Jabbo
10-15-2012, 11:04 PM
Looks good but too many connections and the aluminum tubing is going to bounce around and break free of the silicone connections I would use all silicone tubing keep if simple.
Make-a-Wake
10-16-2012, 12:11 AM
Whats a reality about most of the posts concerning water lines, bullets, wire gauge etc, is that it makes almost no difference when folks are using more than adequate parts to begin with, and and are concerned when the item is 10% 'smaller' than the other option etc...................its not an issue unless someone is involved in sanctioned racing or is using eqiupment that is on the edge for the particular setup to start with.........the measured advantage is so minimal is really isnt an issue.
carlcisneros
10-16-2012, 12:23 AM
Ski;
very nice and tidy.
just make sure and use zip ties on all the silicon tubing.
Jesse J
10-16-2012, 06:32 AM
With water temps in your area, I would say definitely overkill, the only price is the drag from the quad water intake...
If you aren't worried about getting the most speed out of your craft, then no problem.
Remmie81
10-16-2012, 06:45 AM
I would not trust the silicone. Like others said use the special clamps or put same diameter tubing over your waterline.
This way the tubing will not suddenly popoff.
(see picture below for example)
Zip ties will not clamp the waterline in a nice circle. That way you can have a leak or when tightening them to much they can cut into your waterline
Grtz,
Remmie
http://www.x-ray99.com/pictures/var/resizes/Remmie/Pursuit-Mono/ESC.jpg?m=1340009674
Shooter
10-18-2012, 12:55 PM
I like the 'same diameter tube' clamps Remmie. Good idea!
justski
10-18-2012, 03:37 PM
Remmie where did you get the colored tubing
detox
10-18-2012, 03:57 PM
Looks neat...aluminum tubing is inexpensive. What is your setup (motor/esc/lipo count)?
Nevermind...I read you are using Neu 1527 1y 6s1p 5000mah lipos. Watch runtimes using those small 5000mah packs. Packs will puff if not careful.
justski
10-19-2012, 01:25 PM
where did you see that i am running 6s2p 5000mah lipos?........i am not i am running neu 1527 1y with Castle Creations Hydra ICE 240A 33.6V w/Switching BEC and 2 Dinogy Brand Batteries..6s 5000mah 65c ...the reason i ask if it says i am using the 6s2p 5000mah lipos i would like to change it ..............Thanks Jim
detox
10-19-2012, 02:17 PM
I misread. You have plenty capacity. Two 5000mah packs wired 6s2p equals 10000mah
justski
10-19-2012, 04:55 PM
o no its ok i just thought i had it wrong someplace ....thanks
detox
10-19-2012, 05:03 PM
Thats a cool setup BTW. Whoever gave you advice knew what thay were doing.:thumbup:
justski
10-19-2012, 05:07 PM
twin cat told me what to get and how to set everything up so far... but the water lines are my idea i just thought it looked cool
detox
10-19-2012, 05:18 PM
If you feel that the current setup is too heavy, you could go use two lighter weight 4200 6s lipos (8400mah). Lighter weight will run less wet, but of course runtime may be shorter.
detox
10-19-2012, 05:25 PM
I use two NEU 8300mah 3s packs wired in series for my 6s1p setup (1527 1y, Castle LV 240 ICE), but my hull is a hydro.
http://www.neumotors.com/store/page12/index.html
justski
10-19-2012, 05:36 PM
will the NEU 8300mah 3s packs give me a longer time ...this is my first boat so i am still learning ...i want to build another one befor spring that will run longer what motor and batteries will give me a longer run time and whats is a good boat i was thinking of something with a v-hull
detox
10-19-2012, 05:42 PM
Using your same motor/esc the run time will be shorter using the 8300 6s1p. Your two 5000 pack 6s2p will run longer (8300 vs. 10000mah)
properchopper
10-19-2012, 06:39 PM
Nice bends - I wish I could do that. I just built two customer spec FE30's with straight runs of brass tubing - easy and neat.
86789
My Drifter uses a spark plug wire separator I stole from my motorcycle
86790
I hand-made some carbon fiber separators for the Cheetah I built for Cameron
86791
When I find time to rig my Cheetah I think I'll try your polished tubing idea-looks really nice. I talked to Keith about having him crank out some CF separators and he may do so (when He finds the time :wink:)
justski
10-19-2012, 10:37 PM
hey properchopper i used 7/32 tubing and i used my left over 3/16 flex cable inside the tubing to get the bends....on the tight bends i would put my vice grip on the cable and turn it so the cable tightens and shrinks and pull as you turn it worked great
