View Full Version : Brand new Leopard 2450kv 3650 motors with jackets
Skullcracken
10-15-2012, 09:11 PM
86349
Never used, never mounted. The only thing I've done with these is put the jackets on. $125 shipped for both.
bracka69
10-16-2012, 07:49 PM
Hello. Do you by chance know the dimensions with the water jackets on? Also would they possible fit in a 27" Lynx Fighter Cat hull for a twin setup?
Thanks Joshua
Skullcracken
10-16-2012, 10:28 PM
Thanks Joshua
Outside diameter of the water jackets are 43mm. The should fit being shorter motors. I have 36-55mm motors in the 32 inch fightercat hulls. Most guys who put 36mm diameter motors in 32 inch hulls dremel part of the inner hatch lining. Here's a pic of my 32 inch fightercat Geico. Not much bigger than your boat and mine has 36-55mm
86581
bracka69
10-17-2012, 12:38 AM
Ok thanks. Will check my hull and see if they will fit. Original plan is to run a Neu 1515 4100kv. But I'm thinking of going with a twin setup.
